Fisher and Paykel GWL11 Top Load Washer Logo
Posted on Aug 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our FnP GW611 while filling the water stops and starts and after a short time it stops and beeps and the long wash and spin lights come on orange. Any ideas? Thanks
Anonymous
Level 3:
President:
  • Master 1,554 Answers
  • Posted on Aug 21, 2011
Anonymous
Master
Level 3:
President:
Answers
1554
Questions
0
Helped
611845
Points
4917
The problem can be determined through the Wash Progress LEDs. The specific lit LEDs combination indicates an specific error code that tells what generally the problem is. But the exact positions of the lit LEDs are necessary in determining the exact code. Refer to the illustration below and post back the code or the exact positions of the lit LEDs. You may Google for the error code once you determine it, like "Fisher and Paykel Fault Code 37".
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
1helpful
Whirlpool duet washer fills with water (maybe overfills) then stops and the wash light flashes an 8 then 1 type sequence
Hello, we are sorry to hear that you are experiencing this problem. We would recommend having a certified technician out to take a look at the Washer and give the appliance a proper diagnosis. If you would like further assistance you can send your name, phone number, address, model/serial number and the date of which you purchased the Washer to [email protected].
1helpful
I have a fisher and pykel top loader model GW611, when starting on any cycle, on filling the maching the water will pause every so often and may not fill. when it decides to, it starts beeping and shows...
Your fault code is 112
Info for your fault code.
112. (01110000) Motor Current Sense Too High
This fault occurs if the Motor Control Module detects that the motor current has reached an
unrealistically high level for greater than 2 seconds. This suggests that the motor current
sense circuit is faulty.
Primary source: Motor Control Module.
Action: Replace Motor Control Module.
Our FnP GW611 is empty and continues to beep with 3 lights flashing - 2 x just left of short wash + spin light. Any ideas ?
Lights 3,4,8= 49
Lights 2,3,8 = 97 no such fault code.
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
2helpful
Fisher & Paykel Pride 5.5 won't wash. It fills with water then starts to beep. I can advance it to the rinse stage so it drains the water, once the water is drained, it starts to beep again. The...
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
2answers
I have a Fisher & Paykel washing machine. Model MW512NZ. It has stopped working properly. The water is stopping and starting when the machine is filling and although the machine will pump out it will...
Hi just read your posting.Now the lights that are flashing will be in a row of 8 lights.Starting from the left to right which lights are lit,Is it the 2nd and 4th or the 3rd and 6th ---etc---?Please reply with the additional information and I can help you rectify this fault.Looking forward to your reply.
2answers
The washing machine fills with water but then appears like it struggles to spin and then it stops attempting to spin, then starts to beep and flash lights. the lights that flash are the middle green...
Hi just read your posting.Now the lights that are flashing are an ERROR CODE .On the row of 8 lights that these lights are flashing which ones are flashing,starting from the left to right of the row is it the 2nd and 3rd and 8th or the 1st and 4th and 7th ---etc---?Please reply with additional information and I can help you rectify this fault.Looking forward to your reply.
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
6helpful
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
