New Samsung HDTVs use the GREEN RCA input for the yellow RCA video cable, plug it in there. Select the AV input on the TV. For sound, connect white RCA cable to white RCA input on TV.
If you do not have corresponding colored inputs on the plasma set, odds are this TV is a HD/PC monitor only and does not support that type of input. Many of their monitors have inputs from the bottom. Also , some of these connections use a special fitting called a BNC connector. If the TV does support "red,yellow, and white (NTSC composite)", you may need RCA -to- BNC adaptors to connect that DVD player.
