I think u meant installing windows without CD . well for that u have to make a bootable USB ...u need a USB, an ISO of windows xp, and a software like WiNToBootic to make the USB bootable..
u can download the iso from Microsoft site..here is the link http://www.microsoft.com/en-pk/download/details.aspx?id=25129
and u can download WiNToBootic from http://www.wintobootic.com/
give the usb and ISO to WiNToBootic and it will create a bootable USB ..
go into startup options ( when u press a specifit key at startup that menu opens, mine is F12 )
and select USB as a boot option ..(its very clear when u get to each step )
the restart your laptop and boot from USB as you will from a CD.
Use F8 command to get into your desktop - then go to control panel user accounts area and either delete or update the password there and that will do it.
Resetting
a Dell Inspiron to the factory settings allows the user to restore the
Dell Inspiron to the original operating condition as if it was just
taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
some system on your windows has corrupted, it caused by a virus or bad disk you need to restore your system to fix this issue if your laptop build in windows xp and you have a restore disk just follow these steps 1. turn on your notebook 2.quickly press ctr and f11 simultaneously 3. click restore when "Dell PC restore" message appears 4.click confirm (it means you will lost all data in drive which contains your old operation system) 5.wait and click finish when the process of restore finish if your laptop build in windows vista you can follow these steps 1. turn on your laptop 2. quickly press f8 3. when "Advance Boot Menu" message appears just click repair 4. select language and click next 5. log in and click ok 6. click dell factory restore and click next 7. click yes on the box "format hard drive and restore the system" 8. when the process finish click finish if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Cheapest steps first, getting more progressively expensive as the list progresses:
1) Upgrade the BIOS for the system, available at support.dell.com 2) Upgrade the chipset drivers to the latest version, same website. 3) Upgrade the wireless card drivers to the latest version, same website. 4) Re-set the wireless antennas. Usually you can access the WLAN mini-PCI card at the bottom of the systems. It will have two small wires connected to it, one white and one black wire. 5) Re-seat the wireless card. It's like a large RAM SO-DIMM chip, snap-in and out. 6) Perform a system restore (hopefully it doesn't come to that) 7) Re-install windows
More expensive: 8) Replace the WLAN card. 9) Replace the system board.
your type of pc does have a model which you can recover the OS--it runs Linux. Otherwise re-install OS from external drive and OS disc You might be able to do this at a cybercafe
It's usually Control & F11 (which works on my sons 10inch dell) but whether there is a restore partition may depend on your hard drive size.
If you received install/recovery disks, you may have little choice but to get hold of an external CD Drive.
