For that you need to know the password of router. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
If there is modem then connect internet service provider cable to modem .
Then connect lan cable from modem to router lan port then connect lan cable from computer to router;s lan port.
But if there is not any modem then connect direct internet service provider cable to router' wan port.Then connect lan cable from router's to computer.
Connect yellow cable from modem to router's lan port and and connect grey cable from router to computer.But make sure the cable from internet service provider connected to modem.
If modem is configured not as bridge then you need to connect yellow cable to router's WAN port.
Also make sure your router settings is fine you can configure it with below method.
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link.http://192.168.1.1 orhttp://192.168.0.1 orhttp://192.168.15.1 orhttp://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method.
Then click on WAN settings set it as your internet service provider settings enable DHCP
Then click on wireless and enable it.
thank you for that info. however I am not very clever with this technology so I would need a step by step process. I have two cables a yellow one and a grey one. at the moment the yellow one is connected from the modem to the computer. the grey one is coming out of the router from the lan 4 port. where does the other end of the grey cable go. and does the yellow cable get connected to the router and if so which port do I put it in. the router has wan and lan 1,2,3,4. then I am not sure what you mean by what else to do. Do I look up something from the lap top.
again thankyou but you haven't answered my question about where the cables go I don't know.
still can't work it out.
I have connected the yellow from modem to the router lan port and the grey cable from the router lan port to the computer. I have typed in the 192.168.2.1 in to the lap top but nothing happens it just says not connected.
I have also put that same number in to my PC and it doesn't come up with anything either. Where do I type that number.
