LG WM-2277HW Front Load Washer Logo
Posted on Aug 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which side of the dispenser does the detergent go?
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Aug 21, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636393
Points
7414
The detergent goes in the front left side,their is a blue cup their if using liquid,pour it into that cup,if using powder detergent remove that cup and the powder goes there. The Bleach would go behind the detergent& and softner would go in the right rear compartment
Gene
Testimonial: "Many thanks"
1helpful
Troubleshooting
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Gd bless you
Leaves detergent in despencer tray
Most of the time this is a dispenser housing issue. Remove the dispenser tray from washer and make sure it is cleaned very well. In the more serious clogs, you may need to clean the hose from the dispenser to the drum.
  1. Make sure the detergent dispenser drawer is opening. This issue occurs due to jammed soap dispenser. Dispenser Distribution System is located in the top left corner of the washer. The system consists of a motor that turns a cam gear. The Detergent Dispenser Assembly is located under the washer top. Begin by removing the washer top, console and front panel.
  2. Separate the water inlet and window washer tube from the boot. Pull the water inlet tube from the outlet connector of the detergent dispenser. NOTE: When reinstalling the water inlet tube, wet the water inlet gasket on the detergent dispenser with water only. Do not use any other lubricant. Align the tab on the water inlet tube with the indentation on the dispenser connector and slide the tube onto the detergent dispenser assembly.
  3. Remove the screw securing the front of the detergent dispenser assembly to the top front frame member.
  4. Disconnect the vent tube from the detergent dispenser assembly. Remove the screw securing the detergent dispenser assembly to the top left frame member. Slide the assembly back slightly and lift the assembly out.
  5. To remove the detergent dispenser motor assembly,disconnect the cam follower spring and lift the cam follower from the diverter cam and rotate the diverter cam clockwise to access the motor mounting screws. Check for all the connections to the dispenser motor or anything obstructing the dispenser drawer functioning.
  6. Pull the diverter out and clean it, including the shaft, spring, etc.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2helpful
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
1helpful
Detergent dispenser replacement
The front door panel can be removed from the stainless steel inner panel to get to the rear side of the dispenser.open the door & there will be screws along the side.the panel should come away exposing the rear of the dispenser wich then can be undone & replaced.
1helpful
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
2answers
Whirlpool Duet washer, dispenser problem with fabric softner
maybe it's clogged take the drawer out and see if the water flows out of that side ok. put into rinsea nd spin and it should put water into that side.
might take a minute
What happens let me know
make sure you have a towel ready
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
4helpful
2answers
Front Load Washing Machine
Filling laundry detergent and/or additive
dispensers
Dispenser I: (RIGHT SIDE)
Detergent for soaking agent.
Dispenser II: (LEFT SIDE)
Detergent for wash, stain remover.
Dispenser 2: (MIDDLE)
Cleaning product, e.g. fabric softener, fabric
conditioner (do not fill above the lower edge of the
insert 1).
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
