0.5mm pitch ZIF (Zero Insertion Force) mating jumpers
http://www.wavelinkcable.com/flexible_fl...
0.5mm pitch ZIF (Zero Insertion Force) mating jumpers1.00mm pitch ZIF mating jumpers
1.25mm pitch ZIF mating jumpers
1.27mm pitch ZIF mating jumpers
2.54mm pitch ZIF mating jumpers
Direct solder prepared (double-bare traces for bar or hand soldering to PCB)
1.27mm pitch crimp terminated jumpers (solder tabs, female, male, with or without housings)
2.54mm pitch crimp terminated jumpers
might be a loose lead or bad connection if your hinges are loose tighten them up also
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) Ide/Sata make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
hope this helps you:
Thank You very much!!! That helped me like you would not believe.
