Question about LG Televison & Video
When on turn on my LG 47" 3d tv sometimes I don't get any sound. Could you help me please.
  • LG Master
  • 5,569 Answers
A few guesses: If you have any headphones plugged in to a connector, cycle it several times; push in and pull out. These connectors can lose contact inside over time.
2nd guess: Badly flowed solder in the area of the audio circuitry. Although most boards are now soldered by robots and some 'flow-soldering,' out of thousands of such solder points intermittent joints can still happen.
Unless you have some knowledge of what to look for to locate the audio circuitry and some insulated tools to probe with, it may come down to a board replacement and that will be expensive if the audio section is part of the main board what is quite likely.
Another possibility is a connector problem between the power supply board and the main board. You should pull the AC plug and allow the set to rest overnight to ensure that any hazardous voltages have a chance to discharge.
Remove the back panel of the set and locate a smaller board with larger parts visible on it; this should be the power supply. Look for plugs on the main (larger board, smaller parts) board and the power supply (this latter may be also visibly related to the incoming AC line). Carefully pull any plugs you see related to these two boards and re-plug them several times; this will 'wipe' any oxidation from the surfaces.
Reassemble and try it.
Posted on Aug 21, 2011
Anonymous
SOURCE:
Lg model 47ln5750 screen went black
That model is an LED Backlit unit. The LED driver could be bad or there could be a power supply problem. Sometimes the problem is a cable connection. Is there an picture that you can see in a dark room? If you can see a faint picture, the problem is probably the LED back light.
May 18, 2015 | LG 47LN5700 47" LED TV 1920x1080, 120 Hz,...
Remote doesn't work
YOU MUST VISIT THIS SITE
http://www.lg.com/eg_en
Feb 17, 2013 | LG Electronics 47LM7600 47" Class FuHD...
Why do bright colors bounce on my lg tv?
I had this issue on a 40" Seiki TV. I turned off the 120hz setting and also the Noise Reduction settings in the Menu and it stopped.
Jan 12, 2013 | LG 47lw5300 47-inch 1080p 120hz Cinema 3d...
My brand new lg tv went out and has a burnt smell and one of the usb ports does not work. the tv will turn on, but there is no picture or sound
sounds like the main board need to be replaced. call lg for repair, if no warranty you are looking at $300 for the part plus repairman's fee
Jan 16, 2011 | LG 47LX6500BNDL Complete 3D Bundle 47 in...
Televison & Video Logo
37 people viewed this question
Ekse
RONALD CARTER JR
