Maybe the water channel leading to the dispenser valve is not aligned......lid bowed? See Pic
""I have had two bleach dispenser valves fail in the past two years on my Neptune TL washer. ""
Describe fail......did you replace the valves or a repair service?
If you did the work what troubleshooting did you do on the valves? Did you check for 120VAC applied to the valve in Service Mode? Maybe the relay that applies 120VAC to the valve is not functioning or working intermittently........see pic of schematic of Control Board K3 is the Bleach Dispenser relay that applies 120VAC to that dispenser valve. Is it working 100% of the time? If not it may be a Control Board or connector issue ......but you need to troubleshoot.
Did you power up your old dispenser valves with a 120VAC cheater cord on the work bench to verify operation Open/Close?
I'm an owner not a appliance repair tech but have a electronics technical background.
