Posted on Aug 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer displaying E 2 2 - Office Equipment & Supplies
Saleem Baig
Level 2:
  • Expert 283 Answers
  • Posted on Aug 23, 2011
Saleem Baig
Expert
Level 2:
Answers
283
Questions
0
Helped
62440
Points
806
Hi hatti
The E22 is the error is displayed in Canon printers. And it relates to waste ink pad full. follow the correct instructions for perfect results.
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
NEXT
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
NEXT
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
NEXT
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
NEXT
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
NEXT
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
On the end press POWER button to exit .
Take care.
Clearing a Print System Failure on the HP Photosmart C6150 All in One Printer
Try the below steps to bypass the error.
1) Press * and # at the same time
2) Press 1, 2, 3 and "support R0632M" should display
3) Press > and "information menu" should display
4) Press > and "configuration menu" should display
5) Press OK and "hardware failure status" should display
6) Press OK "failure status: clear". Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
You may need to repeat the above a few times as the error can change.
Printer displays "ready 2 download"
No download, dont do it.
Printer
wants to update the firmware,
unless you want to use original cartridges forever.
2helpful
0xc18a001
First unplug the printer, remove the ink cartridges, then re-install the new printer cartridge
If this did not work then follow the alternate steps and fix it .
Resetting HP Photo smart C6180
1 . Press * and # at the same time
2 . Press 1, 2, 3 and "support R0632M" should display
3 . Press > and "information menu" should display
4 . Press > and "configuration menu" should display
5 . Press OK and "hardware failure status" should display
6 . Press OK "failure status: clear". Press OK to clear
7 . Press CANCEL
8 . Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
Now you are done.
Thanks.
2helpful
Hp photosmart C6280 ink system has failed. what do I do?
Please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
5) Press OK.
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
1helpful
Hello , my oki b6200 display error replace fuser E. How to clear fuser counter.
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
The control panel display is blank on my lexmark x6570 printer
If the LCD on the operator panel constantly displays black bars/boxes or other unusual characters, take the following steps:
1. Disconnect the power supply from the printer.
2. Wait for about one minute, then reconnect the power supply and check the LCD display.
3. If black boxes/bars or unusual characters are still displaying constantly, move the power supply to a different power outlet.
4. If the black boxes/bars or unusual characters are still displaying, the scanner ribbon cable may need to be reseated. Do the following:
1. Lift the scanner flatbed. (Open the printer as if attempting to install cartridges.)
2. Look in the back right corner of the 6150/70 for an access cover.
3. Press firmly on the front right corner of the access cover to reseat the scanner ribbon cable that is located underneath the access panel.
5helpful
OKI B6300 DRUM/TONER
try this:
6.Press Ready
17helpful
HP C7180 how do i do a cold reset for this printer?
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
NOTE: E_M_R_E_7@HOTMAİL.COM
Printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
k24674
ADMIN Andrew
ADMIN Andrew
