Question about Vizio 42 in. LCD TV
Hello, pretty simple probably. How do I use the entire screen for the picture, I can hardly read the news scrolls that come at the bottom of the screen cuz of the 3 inches of black border all the way around the picture. I have time warner cable if that matters
  • Vizio Master
  • 8,457 Answers
No.Some u can't changes the tv picture on the screen sizes,because depending the bandwith of ur tv are recieving.Most u can changes the tv on picture to wider screen or to fit the whole tv screen.U have the tv original remote wright?Yes.Look a button that said like Viewmode,Aspect Ratio,Picture sizes,Zoomming.Pushes one of these name buttons u will able to changes tv on screen pictures sizes.
Posted on Aug 23, 2011
6ya staff
SOURCE:
The picture is too big for the screen. It cuts off the heads and you can't see the news scrolls at the bottom
Press Zoom button repeatedly on tv remote to get correct Screen Aspect Ratio that you want to see.
Oct 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I consider whether to use a news app or to read the news byh surfing to a regular news site. What's better?
Seems like a lot of effort is put into creating apps that do pretty much the same as a mobile website. Who wants 5 different apps for reading news? Why not design good mobile websites? I prefer a standard browser, where I can switch between different publications
Sep 07, 2010 | iPhone Apps
I just finished uploading pictures from my camera & when I tried to switch my camera back on it refuses to switch on to take pictures & when I try to look at my pictures I can't see my pictures it...
Sounds like you didn't use the "safely remove hardware" command located at the bottom of your computer screen. If you reset your camera, it will probably work again. Go into the menu and scroll to "reset" and follow the on-screen instructions.
Oct 09, 2009 | Fuji FinePix E550 Digital Camera
Can't read stuff at bottom of screen
it is possible the picture format is set to stretched. look for a button on the remote that can do this. it could also be the signal. try looking at a different channel that has lettering along the top and bottom and determine if the entire picture looks like it needs to be moved up. if after all this you can still determine that the picture is misaligned post the model number and i can help you move it up.
Feb 05, 2009 | Sylvania Televison & Video
TV Screen is stretched beyond picture tube
sorry but that set has outlived it's life expectancy already .only a repair shop can give you any idea what might be wrong
Nov 05, 2017 | Televison & Video
I can't reboot my PC, evrytime I tried to reboot it the following msg comes up at the bottom of the screen " Error Loading Operating System" I also tried to get it to read from the CD, and the...
Hi Abidann,
What operating system are you booting up ? If it is Windows XP you can press F8 during the boot up sequence. A new menu should pop up. Select the 'Safe Mode' option and hit enter. You should then see lots of lines of white text scrolling up the screen pretty quickly, this is the operating system loading the system files. If you get this far, it's good news, and you've probably only got a corrupt registry hive which is fairly easy to recover from.
If you don't even get this far then you may have a dodgy connection to the hard drive that stores you operating system. Check in your bios to ensure that the hard drive is still being detected. If it cannot see the hard drive then either a cable has come loose inside your computer, or the hard drive has failed and you will need to get a replacement.
Fingers crossed it is the first problem though!
David
Nov 19, 2008 | Computers & Internet
Picture size won't fit screen. Can't see scrolling text at bottom (e.g. sports scores on ESPN)
hi there,
its probably not the tv but the set top box you need to fix. go to the settings and select the mode you want ie. widescreen 16:9 etc
then go to the tv and select the full mode or widescreen mode at 16:9
that should solve your problem. it takes some time to find the combination between the set top box and the tv to get it right
good luck
smeags
Dec 30, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Graphics are cut off.
First, have you made any adjustments to the tv other than from the setup menu? If not I have the service manuals for the tv in pdf files and would be glad to send them to you. Let me know I have the same tv and corrected the same problem. v/r, Scott
Mar 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
sounds like a sustained board not really sure a picture would help is it just on one side?
Mar 21, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Vizio 42 in. LCD TV Logo
645 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
