Expert
- Posted on Aug 23, 2011
Re: I am looking for a color access door for a print...
If you are putting in a new cartridge, make sure to remove the tape.
Turn on the unit, then open the print carriage access door.
The print carriage moves to the center of the unit.
Fit the cartridge into the proper carriage.
The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
The carriage with the blue latch is for the tri-color cartridge (HP 57).
Slide the cartridge into the carriage at a slight angle, as shown in the
illustration above. When the cartridge is fully inserted into the
carriage, rock it upright.
Hold the hinged flap of the latch out while lowering the latch.
When
the latch is fully lowered, release the hinged flap. It should catch
under the tabs on the carriage, as shown in the illustration.
Close the cartridge access door.
The LCD display may indicate that the cartridges need to be aligned. Press Enter
on the front panel. You may discard the alignment page that prints.
Remove cartridges
Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
Pull
the cartridge out of the print carriage and relatch the empty print
carriage. The print carriage may move to the right automatically, and if
the latch is up, it could be damaged.
