Any electronics store will have that , so will radio shack, or if you have a FRY's near you, they are pretty common so you should be able to locate one pretty easy
TRY MAPLINS OR A ELECTRICAL STORE OR EVEN A DISCO SHOP WILL STORE THESE FUSES.
TAKE THE OLD ONE WITH YOU AS THEY WILL NEED TO KNOW IF IT IS FAST BLOW CAP ON EACH END WITH A SINGLE WIRE INSIDE OR NOT (IS THERE A SPRING AT ONE END INSIDE THE GLASS TUBE THIS IS CALLED A SLOW BLOW FUSE).OR IS IT IN A CERAMIC WITH A METAL CAP ON EACH END.
HOPE THIS HELPS
NORMAN
