SOURCE: What is the IP Address for Epson TM- U220PD
The best way to connect to this printer is to plug the network cable from the printer into a PC, set your PC to Static IP 192.168.192.100 Subnet 255.255.255.0
Save your settings, and than open internet explorer, or firefox, and access the printer by going to 192.168.192.168
This will allow you to change the settings to your current subnet, and save.
Hope this helps.
Sincerely,
Ryan Deschaine
Systems Engineer
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: [email protected]
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
If you have the same model, on the back of the printer next to the ethernet port is a little button/ hole. Push and hold that down for a couple seconds until it starts printing. It will print out the IP address. Manually assign your computer to have an IP address in the same range (I.E. if the printer says 192.168.1.23, set your computer to 192.168.1.29 with the same subnet mask, etc.). Plug a network cable from your computer directly into the printer. Then, you can change the settings.
SOURCE: Connection problem with Epson TM-U220B
try holding the button on the interface card and checking your network settings for three seconds and check on how to configure your interface card. That's a start.
