SOURCE: Warm refrigerator
Some simple things you could check. Can you tell how long compressor runs. Are both fans running while compressor is running? Is the compressor to too hot to touch? Is the condenser under refrigerator giving off warm air? And if all these things together while running and compressor not stopping, what is the freezer temperature and evaporator heat being taken away with the condenser fan? Is your freezer defrosting properly and have you checked the adaptive defrost control. Below is a link to that model. Put model number MSD2756GES into the search model feature and it will take you to your model. Click on photo 2 controls and part # 13 in the controls photo is what you need to have a look at, Let me know what you find and I will answer the compressor change now. ( Not worth changing if refrigerator is old) Let me know what you find, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
SOURCE: Maytag refrigerator side stopped working; freezer is fine. WHY?
sounds like a defrost problem maytag has problems with the defrost thermostat use a hair dryer to melt the ice on the coils and see if the defrost thermostat is swelled up on the edge
SOURCE: 26 Cu Ft Side By Side Maytag Refrigerator: Relay Failures
you have more than likely got a bad compressor it is pulling to many amps you need to replace the compressor
SOURCE: No refrigeration to freezer or refrigerator
By what you are telling me, it seems the fridge compressor has gone faulty(Assuming you have 2 compressors). If so possibly it has tripped on over temp for what ever reason. suggest you turn fridge itself off and let it cool for approx. 1 hour. Retry and see. If it continues to not cool, then call a technician. If you have only got one compressor, then it becomes a little more complex. Either your auger motor which feeds the fridge is frozen or the evaporator fan motor is stuck or defective. "my guese it is stuck"."Need to do a proper defrost."
SOURCE: fridge is no longer cold
Either a bad relay on the compressor. Or a scized or locked up compresor. My co. in NJ gets $95 to replace the relay, $450. to change compressor. $25.00 just to check it out. The Dealer is always more $$
Shop around, Smaller companies, smaller price.
If your unit has a Embraco compressor it may just need a new relay. The Tecumseh compressors all went bad and now are replaced by Embraco's
Freezer Back Panel
NOTE: Freezer compartment should now be empty and
walls should be clear of anything that will
obstruct removal of back panel.
1. Loosen screws that mount icemaker to freezer
compartment walls.
2. Pull icemaker gently away from wall of compartment.
As you do so, work fill cup free of fill tube. Unplug
icemaker electrical connector and remove icemaker
from unit.
3. (Pull out Drawer only) Loosen and remove screws
that hold 2 basket glides in place at left and right
sides of compartment.
4. If unit has no icemaker pry with flatblade icemaker
connection cover. Remove cover.
5. Remove hex head screws that hold back panel and
remove panel.
6. Squeeze tabs on ice maker plug to release it from
back panel
Defrost Terminator (Thermostat)
1. Terminator is fastened to evaporator tubing with a
spring clip.
2. Snap terminator off tubing and cut wires to terminator.
3. Remove terminator from unit.
That is word for word.
See parts list diagram here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=28480593#d28480593
This may help with screws but the defrost thermostat is item 32 and not shown on the diagram. Once you hav ethe access panel off loof fok the thermostat. It will have 2 wires and tough metal clip on it.
Thanks for choosing FixYa,
Kelly
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
