There is a system error then. If a red LED is blinking and the TV is not working properly it means that the TV has detected an issue or problem. Most of the Red LED blink conditions will require being service. Check how many times the red LED light will blink and then contact Sony for support.
power will not come on
Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Samsung TV won turn on blinking red light explained fix 18
Main board fault. Shorted component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
I'm sorry, I don't have a solution, but I seem to be having a similar problem. When I turn my TV on, the green light comes on like it's powered up, but then the TV turns itself back off and the red LED light flashes. I can't do anything to turn it on or anything.
tv clicking red light flashing but wont turn on...
flashing red wont turn on
flashing red light comes on when turning tv on but tv wont come on
hitachi 32ld8d20u a
