Televison & Video Logo
Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No picture at all on my Bravia (4yrs old) but have sound, I suspect it's a problem with the backlight.
Anonymous
Level 2:
Scholar:
  • Expert 115 Answers
  • Posted on Aug 25, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
115
Questions
Helped
21707
Points
323
Usually in that case the problem is the backlight.There is no supply in the backlights cause of loose connection because the backlight have high voltage.The connector of the backlights at the board or driver supply is loosen.So its better to check the connection and resolder or fix the connection.Thanks..
Sony Bravia KDL60EX640 has sound but no picture all black on screen
Check its back light inverter baord. There is no backlight. Check the reason for it. Check the voltages comes to backlight inverter board, for its power regulator board. For more information go to http://electronicshelponline.blogspot.com/
Sony bravia kdl46bx450 has sound but no picture
Sounds like you have a backlight problem. I would suggest turning on the set, dimming the lights in the room. Take a bright flashlight and shine it on the screen, do you see a faint picture?
I have sound but no picture
oh, so that's your problem. I'm willing to bet you have a picture but just no backlight. Now does the screen come on briefly when you first turn the TV on? Or is the screen black at all times?? Turn on the TV, turn off the lights in the room. Take a very bright flash light and shine it one the screen.I bet you see a dim picture. It sounds like you have a backlight problem. Either you are missing 24VDC from the power supply, 3.3VDC "backlight on" signal from the main board, a bad inverter, or a bad backlamp.
Resolution problems
could be the backlight or the inverter. the only way to tell for sure is to take the laptop apart and install a new inverter. although it really sounds like the backlight which is not cost effective to replace just the backlight, you're better off buying a new screen on ebay or something.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
3helpful
Black screen , red standby light flashing 4x repeatedly, unplug it and the green light comes on momentarily then resorts to 4 red flashing lighrts again. Sony KDL-40V2500 approx. 4yrs old. HDMI cables are...
4 blinks indicated of backlight malfunction. The unit shutsdown to avoid overload to the inverter board.
Check the backlights, busted backlight has a physical indication of fault like blackened end, crack end. You must replaced the busted one and your unit will back to normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
9helpful
Sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Brand new sony bravia flat screen tv - sound but no picture - elderly lady neighbour has asked for help
Can you see a backlight on the screen? If not then there will be problem with the screen invertor.If there is a backlight then the problem will be the T- Con board..If the tv is brand new then you will get it repaired free under warranty if less than 1 year old. Hope this helps
4helpful
3answers
NO POWER?
Ur power IC invertder board it dead.
Need a new one.
Tries the Sony Website buy the power board.
MIght work or some things else might also burned.
Sony bravia
It sounds like the backlight is going bad or possibly the panel. Let me see a picture of it. Talk to you later. Jay
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
