Question about Epson Perfection V700 PHOTO Flatbed Scanner
I cannot get clear scans from my photo negatives
When I scan my photo negatives from a medium and large format camera, I am not getting clean scans from my Epson V700 photo scanner. I have changed the file sizes for the professional photo lab to work with as they recommended, but we are still seeing pixelation on the prints once they have been printed.
When I purchased this photo scanner, I was told it would provide good quality scans but since attempting to do the scans myself, we have experienced fair to poor results. Very disappointing.
I have tried taking the negatives out of the holding frames in an attempt to get a clearer and cleaner scan on the glass since it offers a flater surface but have not been successful.
The techs at the photo lab I use are very knowledgeable and are wondering if there is some way to adjust the focus on the scanner. Per their guidelines, I have scanned the negatives in a Tiff file and have increased the MB sizes of the files. Still unsuccessful.
My understanding was this was a "higher-end" photo scanner able to provide good quality photo scans at an affordable price. I realize to get the highest quality I would have to invest in a far more expensive scanner. I didn't have the funds to purchase one of those, however, was assured by Epson's sales department that this scanner was quite capable of meeting my needs.
Do you have any additional suggestions that I might try? Do I have a faulty scanner? Is there a way to adjust the focus on this particular scanner?
I would really appreciate any feedback you might offer.
Thanks!
  • nikos006 Dec 21, 2008
    Scan are not clear. I scanned a lot of photographs a few months ago and all worked perfectly, but now, all the negatives I scan are trouble. I tried to change all the plastic parts from the guides(from + to 0, and then putting them off) but it still doesn't work.
  • 35 Answers
If you are seeing pixelation, the issue is either insufficient resolution during the scanning process or a problem with the output device. If it's a focus issue, which will NOT cause pixelation, the problem may be the height of the negative holder. The Epson Perfection V series scanners have a fixed focus point which only adjusts between two settings depending on whether you select the film holders (which raise the film off the glass) or the film guide (which scans film directly on the glass) in the software options. If you are going to scan transparencies or negatives, familiarize yourself with the holder height adjustment issue and be willing to experiment with different height settings until you are getting optimum results. This is not documented much at all in the Epson user manual but there is a little bit about it, including some examples of results at different settings, here: http://www.photo-i.co.uk/Reviews/interactive/Epson%20V700/page_13.htm Apparently every scanner is slightly different so even though the lowest holder foot setting (default) is working best for some, other settings work better for others. On my V700, I have the feet on the film holders set to the highest setting plus I shimmed them with a 1mm piece of styrene before I could get the scans in focus. Once I found the right height though, I've been able to get beautiful scans from this machine. BTW, scanning negs directly on the glass will almost always result in Newton Rings.
Posted on Jun 14, 2009
6ya staff
SOURCE:
How can I find out if there are digital scanners available for 2.25 square negatives.
Given the popularity of these films (Kodak 120 or 620, dependent upon size of hole in the spool) there are scanners available.
However, the negative is large enough that ordinary flat-bed scanners with a film attachment will be sufficient for scanning.
http://photo.net/medium-format-photography-forum/00cN3y refers.
Jan 29, 2015 | Photography
Can not scan negatives and slides
Download this manual and select "scanning films and transparencies" section and follow the instructions.
https://files.support.epson.com/pdf/prv7ph/prv7phug.pdf
Aug 07, 2014 | Epson Quality V700 Photo Scanner
Scanning 110 Instamatic slides on Epson Perfection V700 photo scanner
Hi Stanley - does this youtube video help? http://www.youtube.com/watch?v=EcALdbbCnSk
If not, let me know and we can investigate further.
Regards,
Justin.
Jan 17, 2014 | Epson Perfection V700 PHOTO Flatbed...
Does the soft ware in the V700 support early colour negative material ? I can find Ilford HP5 but not Ilfocolour !
There isn't a specific template for that film, but you can try out with generic settings and see how it goes. I rarely use the specific film settings from scanner software, and always prefer to adjust them to each roll I scan. Good luck with that! :)
Jul 09, 2010 | Epson Perfection V700 PHOTO Flatbed...
I am having problems scanning 35mm slides, I seem
you have chosen normal preview
1. change it to thumbnail preview
2. or click on "All" button in normal preview
so you would scan multiple negatives.
increase your dpi setting or your target area or both
I am also scanning color negatives at 3600dpi and 48bit. file is large but quality is very very good...
Mehboob Riaz, SIPA, Lahore-Pakistan
Jul 08, 2010 | Epson Perfection V700 PHOTO Flatbed...
I have an Epson Perfection V700 Photo scanner and an Imac version 10.5.8. Are these compatable?
Yes the scanner is compatible with a downloaded driver from epson. however some of the supplied third party software may not be. Also with MACS the push button scan may not work.
Dec 28, 2009 | Epson Perfection V700 PHOTO Flatbed...
Epson V300 Photo Scanner Streak When Scanning Negative
I also own a v300, and I have noticed that I occasionally get rainbow streaks if I bump the scanner at all while it is scanning negatives, so this might have something to do with vibrations in the machine. Is it sitting on a stable surface?
Mar 14, 2009 | Epson Perfection V700 PHOTO Flatbed...
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Jan 22, 2008 | Epson Perfection 3200 Photo Flatbed...
Epson V700 Photo Scanner
are you scanning it at the right resolution and are you using the negative holder?
Nov 09, 2007 | Office Equipment & Supplies
Epson perfection 4990 photo scanner
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Epson Perfection V700 PHOTO Flatbed Scanner Logo
786 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
