SOURCE: IMac and ADVC 110 via firewire = Nothing
this just happened to me tonight...whats going on?? is this some recent leopard related error?
SOURCE: Canopus ADVC 110 converter box not working
Plugging in the FireWire backward, especially if it's the 6-pin FireWire, will damage the unit's hardware. You need to contact technical support to arrange for repair.
SOURCE: cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
SOURCE: Can't capture just audio with no video
Capture it as a standard video clip (with audio), then export the audio track out of Final Cut. If you export as 48 KHz, 16-bit stereo, then there should be no loss in quality as the output is the same as the captured input.
