The small permanent magnets that start the field producing the electric have gone flat or lost their charge.
To get the generator part working again you will need to "flash" or reintroduce power back into the magnets.
This can be done in many ways... click here for one way
Here is another way to do it...
There are more if you want to google it...
heatman101
It did not work until I sped up the motor to run faster. Then it worked fine. If anyone else has this problem, you might add that. I flashed it, nothing worked,then I sped the motor up to run faster and like I said, it kicked in and worked good. Thank you.
how did you speed the motor up
