scan it to a file
Find program called hpscan in your list of all programs to scan to file.
This is usually what it is called with hp scanners
Note the directory that the file is scanned and saved to .
and then attach file to email message using attach file option on email program when you compose email message.
You need to adjust the resolution in the software. Are you using the Dell software and PaperPort or another application?
This will be easiest to do when you launch the scan from the computer. If you have the TWAIN driver loaded, load the document to scan in the ADF and open Paperport. Click FileScan and the available scanners list should open. Choose your scanner (otherwise click the Select button on the left side of the window). Then click OK. Click on the Scanner Display dialog box on the left of the window. Click on Preview. Then adjust the resolution by clicking on the Image Quality tab.
If the document contains is only a series of picture or you have the WIA driver loaded, then use Paint or PhotoGallery (Vista includes the program, but it is available for XP or Windows 7). Then choose File > Import from Camera or Scanner > From Scanner. Open the Advanced Properties dialog box by clicking on Adjust the Quality of the Scanned picture.
I hope this helps.
Cindy Wells (The default resolution is used when you launch a scan from the unit itself. It is possible to adjust it once the software loads but you must use the scan to file option, instead of scan to e-mail. Then attach the resultant file to your e-mail.)
Hi I think you will need to run the cd installer again to install the scanner driver on your printer.
You can check if the driver of the scanner was successfully installed once you view on the Scanners & Cameras inside the Control Panel and see the image of your printer scanner. It means it is connected and ready to be used. If you can not see the icon of the printer scanner there, then, it could not be installed or the printer is attached to other pc in the network.
Remember to use the printer as scanner, it should be attached locally to the pc you are using. Pressing the Scan button in the printer will save the scanned documents in the computer as pdf files. In order to save the documents as jpeg files, you must need to use the scan option on the Scanners & Cameras inside the Control Panel.
Hope it helps. Just post back if you still have questions.
1. place doc in scanner and scan it 2. save scan item where you can find it 3. go to email program and select attach file 4. select the location and file you want to attach
THERE ARE NO OF DIFFERENT WAYS TO SCAN SINCE YOU HAVE'NT MENTIONED THE O/S OR THE TYPE OF PRINTER/SCANNER YOU HAVE TRY THIS !! OPEN All Programs , click Accessories , and then click Paint . Click File , and then click Import From Camera or Scanner Make any desired setting changes, and then click Scan . IF YOUR SCANNER IS WORKING THEN IT SHOULD WORK
NOW YOU CAN ATTACH THE SCANNED DOC. USING THE ATTACH FILE OPTION IN YOUR EMAIL AND SEND IT ALL THE BEST !!!!!
You can scan to your computers using below steps and save it to your PC, after you save the files, you can attach them to your email .
Windows XP:
1. 1. Click the Start (Windows) icon. 2. Click All Programs. 3. Click Accessories. 4. Click Paint. 5. Click File and then click From Scanner or Camera. 6. Click Scan.
Windows Vista:
1. Click the Start (Windows) icon. 2. Click All Programs. 3. Click Windows Photo Gallery. 4. Click File and then click Import From Scanner or Camera. 5. Click Import. 6. Click Scan.
Thank you for allowing me to assist you in this question. Below is some basic information on how to scan with this printer. The Kodak Home Center software will save the file into a directory into your computer and you can use your email program to attach that file into your emails.
To scan to a file 1 Set the Default scan destination to File with the Kodak Home Center software. 2 Place your original face down in the right front corner of the scanner glass. 3 Press Scan. 4 Press Start. The original is scanned and saved to a file on your computer according to the scan settings in the Kodak Home Center software. To scan to an application 1 Set the Default scan destination to Application with the Kodak Home Center software. 2 Place your original face down in the right front corner of the scanner glass. 3 Press Scan. 4 Press Start. The original is scanned into Kodak Home Center where you can open it with the application of your choice.
