Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer (twain driver vs.3) does not recognize the scanner. I have re-started both machines and still no luck. Can you help?
Joel Baleta
Level 2:
New Friend:
  • Expert 155 Answers
  • Posted on Sep 10, 2011
Joel Baleta
Expert
Level 2:
New Friend:
Answers
155
Questions
Helped
56117
Points
211
Uninstall the driver and then reinstall it again, maybe the installation is corrupted.
2answers
Can't connect fujitsu 5120c scanner to windows 7 machine
To connect your Fujitsu fi-5120c scanner to Windows 7 PC, you need to install the TWAIN driver for Windows 7. Please download the driver update from the link provided below:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v9211013.html
Hope the above information is helpful.
Please feel free to to contact us for further assistance.
Thanks & regards,
ScanCare
2answers
Keeps saying "scanner failure" What do I do?
Scanners are a real legacy issue within windows - they have been there forever and yet the software controlling them hasn't been improved on - TWAIN it is the name of the Toolkit which communicates with your scanner and the proprietary software sits on top of that. TWAIN stands for "Toolkit Without An Interesting Name" - I think says it all. It hasn't been improved on much through the various releases of Windows. But to help you more we would need a lot more information.
- Platform Windows 7 .... Mac ...
- Scanner name and manufacturer
- Type of connection to the scanner ( USB ¦ WIRELESS )
- Whether you have had the scanner working in the past on this machine.
- Does the scanner work on another machine - Do you have another machine on which to try the scanner.
- Do you have the original disks for the scanner. And the original Windows Disk - so that you can load up the TWAIN software.
- How did you install the software for the scanner
- Have you come across this TWAIN driver ( perhaps you haven't installed that - because the Manufacturer's software doesn't include the TWAIN driver ( you have to load that from your Windows disk )
If you haven't loaded the TWAIN software - then perhaps - you should de-install the Manufacturers software and then install the TWAIN driver from the disk ( although - it may already be resident in the bowls of the Windows environment on the machine ) and then finally re-install the Manufacturer's software ...
So more questions than answers - but I hope that helps ....
Greg McC
4helpful
2answers
I have a Ricoh Aficio 1515 MF. I cannot get my Windows XP Pro to recognize the scanner, and I downloaded the Twain driver from the Ricoh site. Help! I want to scan into Adobe Acrobat.
Does the machine show up on your computer - you can print?
do you see it in scanners and cameras in start - control panel -> scanners and cameras? what is the status shown there on the properties?
1helpful
3answers
Cant get my computer to recognize my SprintScan 4000
The scanner uses a "twain" driver, try searching for that, it may be one of the files you already downloaded. Just look in the download u got.Also try going to add hardware, select the scanner there and poit it to the downloaded file when uit asks if you have a disk that came with it. Download the drivers to your desktop, rt click and open a folder on the desktop, and drag all of the drivers and the Twain one especially, into the folder.
3answers
I have a Canon scanner 5000f. All of a sudden the computer won't recognize it and says it is "unable to select Twain Source." What do I do?
First you need to follow the instructions for installing the scanner. It is important whether you connect the scanner before the software is installed and whether you work from the new hardware found box or just install the driver as software. It sometimes varies between operating systems as well.
Sometimes the twain files can become corrupted. Since other devices like digital cameras use the twain files they aren’t erased with a driver uninstall or overwritten with an install. If the twain files are gone the driver install will also install them.
Uninstall ScanGear (I think that is the Canon driver software) and remove the scanner if it is still showing in device manager and control panel under scanners. Unplug the USB.
Do a search for twain and delete all you find in the Windows folder. There is probably a folder and several files – delete them all. Do not remove any twain files not in the Windows folder.
Dig out the instructions and reinstall the scanner exactly according to them.
Innoscan dts3050
1. Uninstall any twain drivers you have in stalled for your scanner. RESTART
2. Install I/O driver "Port IO" from http://www.driverlinx.com/Software_Products/softwareproducts.htm .....RESTART
Port IO driver
3. In stall your twain driver http://www.maginnovision.com/Service_Support/drivers/dts3050.html
RESTART
Twain driver
2helpful
TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Epson CX 3200 - twain error scanner not recognized
Click HERE for a troubleshooting guide
Click HERE for drivers and documentation
1helpful
3answers
Twain driver for scansnap s300
The scanner can not be used with Twain.
3 TWAIN or ISIS® applications cannot be used directly.http://www.fujitsu.com/us/services/computing/peripherals/scanners/scansnap/s300.html
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
