Comfort-Aire BHD-301 Dehumidifier Logo
Posted on Aug 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I stored two different comfort air dehumid. for about 6 months & strangely both now leak. They leak at the bottom opposite of were i have the drain hose attached to a draining garden hose. The hose needs to drain up about 8 inches to get out of the room is this the problem, drain up? Thanks
Anonymous
Level 3:
  • Comfort-Aire Master 43,501 Answers
  • Posted on Aug 26, 2011
Anonymous
Comfort-Aire Master
Level 3:
Answers
43501
Questions
0
Helped
10837871
Points
101584
Yes... set the dehumidifiers up on blacks so that the hose drains downward and your problem will be solved... make sure the hose is supported so that it steadyly slopes downward and does not trap...
The outlet is very crappy and the hose does not seal well ...also make sure the hose end has a washer in it...
heatman101
Bucket removal is extremely difficult. What should I do?
There's usually a piece or tubing that hangs down into the tank and you need to pull your tank past this when removing it to drain your dehumidifier. Are you lifting from the top or bottom? Try the opposite of what you are doing. Sorry I don't know your model specifically, but often there's an outlet or cap at the bottom of the tank that can have a plastic piece of aquarium type tubing hooked to it. This way if you can elevate the whole dehumidifier, say on a counter, the water can just drain into a sink or if you're a real conserver into a storage tank to use to flush your toilet or water your grass.
2answers
Bucket fills but unit will not stop dehumidifying.
probably a bad switch at the float assembly...check that out....probably going o have to replace that. check also for loose or disconnected wiring at the switch. let me know what happens
Garrison 50 pint dehumidifier/ AC unit. Showing error 4, water leaking from bottom of unit?
Drain line stopped up .
If no drain line? Unit has to be emptied regularly
answers.canadiantire.ca > ... > Heating & Air Conditioning Q & A
Why is it common for dehumider to frost up and then defrost?
To my knowledge this is not normal. It probably is a little low on refrigrent but to verify that be sure the air path is clean and the fan is operationg properly. Low air flow would also cause that type of problem.
Dehumid....ad70usso....runs all the time auto settings don't seem to working collects fine ..but won't turn off when air is dry thanks
There are 4 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. Also, keep in mind, basements stay moister longer than upper rooms.
1. The humidity extraction level is set to HIGH. Lower it to 32-35% and disable the auto mode.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I have had a m old problem in my apt. how can I keep the mold from growing in the dehumidifier? bonita
One thing that I have had good results with on controling mold and bacterial build up is to add a couple of ounces of chlorine bleach every month. You can purchase commercial products to do the same thing at most hvac supply stores. They do smell much better but are not cheap. Hope this helps you. Thanks
1helpful
Comfort Air Dehumidifier BHD-501-1
Yes, you have a sealed system leak. Call the number in the book. I beleive that unit is manufactured by LG. You will need to have the unit diagnosed at an authorized LG repair provider. If the unit is under warranty, it will then be replaced by LG no charge, including the diagnostic. Make sure to bring in copies of the proof of purchase. The replacement unit will be shipped directly to you, and you will need to return your old unit, but shipping will be covered by LG with a pre-paid shipping label.
Good morning--my Comfort Aire dehumidifier will no longer run & is still under warranty. When I turn it on the red light just comes on.
May be power supply failure, faulty control panel or other problem. It may just need to be left unplugged overnight for reset.
The unit has started sweating cold water droplets on its top and in the last couple of days it has actually frozen.
Several possible problems. Filter clean? As strange as this may sound you may have lost a little refrigerant. If problem persists after filter is cleaned, then a Tech needs to look at it.
H20 POURS OUT OF THE UNIT BEFORE BUCKET IS FULL
It sounds like your unit is freezing up. Let it set for a day then set to run on the 3 hr cycle. Also rase the % of humidity to 60 or 65, and if it starts working lower the % setting in a few days by 5% increments until you get to the setting you want. Also read your owners manual troubleshooting section lots of good tips.
Jimh32851
Top Comfort-Aire Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
