I just replaced the bulb/lamp on my LG RU-52SZ51D TV. It was fairly simple. Basically you have 2 screws that hold on the cover panel on the right side of the TV. Once you take off the cover, you'll then see a metal tray with a handle. That has 3 screws, you can then pull out the tray and see the bulb/lamp. The lamp has 3 more screws that hold the little brackets that hold the lamp in place. Last you have the 2 power wires. One is connected by a screw on the left of the lamp, the other is attached by a nut and a washer on the back of the lamp, where you would usually screw in a normal light. The two wires are just connected to a single plug to the right of the lamp which you can remove, you get the new lamp with the wires already attached. All you have to do is plug it in after you mount it back up. Here is the info on purchasing a lamp, sorry but I am still in the process of learning how to reset the lamp indicator light...
Website:http://www.partstore.com/ProductDeta...ModelID=491016
Zenith Projection TV Lamp
Zenith Part Number: 6912B22002C
LG Electronics Model: RU52SZ51D
Don't miss your favorite programs, keep an extra Zenith TV lamp on hand. NOTE: THIS PART IS MANUFACTURED BY OSRAM. IF THE OLD LAMP WAS MADE BY OSRAM, USE THIS PART.
Price: $ 273.83
Here is how to reset the lamp timer.
lamp reset on lge :to reset lamp timer press and hold ENTER or OK on tv display and MUTE on remote at the same time for 5 to 10 seconds, lamp reset box will pop up you can then reset lamp.
