Zebra Z4M Printer Logo
Posted on Sep 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer erorr after down load of firmware
I downloaded firmware to a printer. The download look like it completed ok. But the print it still having download firmware and the erorr light is on the printer. It has been setting like this for 8 hours. I can get into the control panel of the printer. When I recycly the printer is comes back the the same message. Clear this out and reset the printer. thanks
Ginko
Level 3:
  • Zebra Master 19,396 Answers
  • Posted on Sep 09, 2008
Ginko
Zebra Master
Level 3:
Answers
19396
Questions
25
Helped
8077761
Points
55462
The printer probably failed in the final phase of download firmware.
After eight hours it is clear that the firmware setupwas not successfull.
This may have damaged the printer.
Keep the on button pressed for ten second, see if the printer turns off.
Try unplugging printer power cord, leave the printer unplugged for thirty minutes or so.
If the printer does not restart, the firmware inside the printer had been damaged.
In this case call the support number listed on your user manual.
If printer restart upgrade firmware again.
HP 8500 Shuts down after a few hours
Hi David,
Try the firmware update for your printer released by HP. Click on the link below and select the Operating system from the list.
Click on + on Firmware Update. Download and Install.
Download Firmware Update
Regards,Suhail
My 5250 printer cannot load paper properly. It loads unevenly and displays error messages 3424, 3618, or lately 3520. I tried to upload new firmware, but no new firmware is available.
Hi there.
The error 3520 requires a firmware upgrade. Please click on this link for the firmware update.
Installation Instructions:
  1. Verify that the KODAK All-in-One Printer Home Center Software is installed and can communicate with your printer.
  2. Download the firmware file to your computer.
  3. Double-click the *.exe file, then follow the on-screen instructions. Wait for "Update complete! You may now use your Kodak Printer." to appear on your computer.
  4. Click OK to complete the firmware installation.
If your using a Mac, please click on this link.
Let me know if you need further assistance.
Thank you!
Download file now send rfu upgrade on usb dev port
Determine the current firmware version 1. Press Menu . 2. Press the down arrow to highlight INFORMATION, and then press OK. 3. Press the down arrow to highlight PRINT CONFIGURATION, and then press OK to print. The firmware datecode is listed on the Configuration page in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.***.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20061125 represents November 25, 2006. Download new firmware from the HP Web site To find the most recent firmware upgrade for the product, go to www.hp.com/go/ ljp4010series_software or www.hp.com/go/ljp4510series_software. This page provides instructions for downloading the new firmware version.
Good day, i have a 4730mfp. it does not print colour correctly, the print out appears faded like the printer is out of toner, even after all toners are changed.
First thing to try is this, please go to control panel on the printer and to aministration menu. Scroll down to troubleshooting and find the PQ troubleshooting option and press ok. This will print a series of test prints. If these prints look OK then likely you have an issue with your driver. If they are faded, the second thing you need to do is check to make sure that your firmware revision is current. On the config page that prints with the pages just printed above, look on the upper left for firmware revision. Current version is 46.300.0. Download from here and install following the instruction in the readme file. Did it print OK before changing cartridges? If you installed remanufactured or 3rd party cartridges, the toner will not always provide the same quality of print.
2answers
I'm wondering how to repair a 49. 4C06 Service error
See if the error is only occuring with a particular application or certain documents. Most times the error is related to the use of Adobe. If you have a network and are using a print server for all the printers, then the first thing I would do is load one of the problem printers locally on one or more pc's using tcp/ip and the driver being loaded on the local machine. See if you still have the issue. If not, then the print server may be causing issues. If you still have the issue, especially with the 4250, then I would contact hp tech support. Keep in mind if it is only happening with a certain application, HP will tell you to contact that vendor. One other note is that I have seen this type of error of the 4200 and 4300 series when users were printing lots of documents with foreign language characters in them. On those, though the firmware upgrade solved the isse.
We are having problems printing certain types of pdfs with the 4240n. They are causing the printers to completely stop printing or slow down. How can we fix this?
Start by upgrading the Firmware. Go to www.hp.com, enter the printer type, select the OS, drill down to Firmware. Click Download. Click the README and please read it.
9helpful
2answers
How can i solve error canon Ir2016 (download standby) error
Hi, you need to upgrade firmware from start. Download standby is message that appears when system is colapsed and when you want to upgrade firmware from service mode.
When printing envelopes the printer suddenly prints fact sheet
have you updated the firmware on your printer? hp has a firmware update utility down load for it that just might help you with your problem. iu fixed a simular problem by using the download
15helpful
3answers
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
