Question about Apple iPad (16 GB) WiFi Tablet PC
My wifi on my iPad isn't responding,It says ''No Wi-Fi'' even though our internet connection is on. It never changes from gray to blue when you touch it.
  • 3 more comments
  • Anonymous Mar 14, 2014
    My internet isn't working with wifi even though it says connected and let's me get onto Facebook, I'm trying to download candy crush, its a brand new kocaso.
  • Anonymous Mar 15, 2014
    Is there an app update to get wi-fi streaming from ipad
  • Anonymous Mar 19, 2014
    TRYING TO SET I PAD TO WI=FI
  • Anonymous Mar 20, 2014
    Wi-Fi doesn't work properly
  • Anonymous Mar 30, 2014
    My wi fi disconnects from my ipad. How do i reconnect it?
    Guru:
  • 192 Answers
This sounds like a hard ware issue with you wifi antenna. Restore your device using iTunes. If it is still grayed out take it in for service at a local apple store or authorized service provider.
Posted on Sep 14, 2011
6ya staff
SOURCE:
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
Why won,t ipad connect to wifi , keeps saying not connected but was 2hours prior
are there any other devices connected to the same wi fi are they working ?
TRy powering down wi fi router
Feb 20, 2015 | Apple iPad (16 GB) WiFi Tablet PC
How do i find what my wi-fi is. is there a list? for my new gb64 apple iPad
Once you pick a wifi you want to connect then enter the password and it should allow you to connect.iPads are notorious at remembering old passwords for any previous connection so if you still can't connect you need to scan the wifi then instead of connecting click the right arrow to get to forget network.then rescan...then re input new password.viola!
Feb 16, 2015 | Apple - iPad Air 2 Wi-Fi 64GB
How do I connect an iPad to the internet?
Do you have wi-fi? If so, in the settings, go to 'wi-fi' at the top of the page. Click on 'choose a network'. Type in the name of your network and the password (this information should have come with your router). That should get you set up with the Internet.
Feb 13, 2015 | Apple iPad 2 Wifi 16GB
Can I convert a wifi iPad air to cellular?
no it cant. Unless you have a wireless hotspot. With a wireless hotspot you can connect your ipad anywhere you get a phone signal.
Oct 27, 2014 | Apple iPad Air 9.7" 64 GB Wi-Fi Space Gray...
With iPad must I join an internet even tho it is connected to my desktop usb?
Simply go to Settings-second down on the left menu, choose Wi-Fi and on the right menu, your home (or wherever you are) wi-fi connection should appear by name. Then simply touch the one you want to connect to. You should see the choice you made on the left menu next to the word Wi-Fi. I only connect my iPad to my computer to charge it occasionally via USB.
Sep 20, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How reset ipad passcode
  1. Start the iPad
  2. Tap on the Settings app
  3. Tap on the Wi-Fi category
  4. Choose a Network
  5. Once you Tap on a network name, it will try to connect to it. If the network is using wireless encryption, though, you will be presented with a screen asking you to enter the wireless encryption password.
How to connect an iPad to Wireless or Wi Fi network
Aug 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
HOW DO I activate my apple ipad A1432 to enternet
Settings > Wi-Fi > flip the on/off switch ( when you slide the switch it will become blue ) > after Wi-Fi is on it will give you an option/options on which Wi-Fi server to connect to > click on one > see if your internet works then .
Nov 13, 2013 | Apple iPad 32 GB WiFi Tablet PC
Can't connect mini iPad to my wifi my other iPad is connected
Always a good idea to shut down and then turn back on (hold down both home button and power button until it turns all the way off. Wait a couple seconds, then press the power button to turn back on)
Try wireless again.
If nothing, then
Obviously check and make sure wifi is on under settings.
If still nothing,
Try resetting your network connections:
Settings > General, then tap Reset > Reset Network Settings
If you can't see any wifi networks at all, you might have a bad wifi card in the iPad. Bring back to an apple store.
Jan 31, 2013 | Tablets & eReaders
How to connect to the internet
Click on settings then click on Wi-Fi (make sure that the wi-fi is switched on on the ipad) then find your wi-fi router and then when prompted enter your user name and your password. Hope this helps.
Dec 25, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Apple iPad (16 GB) WiFi Tablet PC Logo
196 people viewed this question
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
