Hyundai ImageQuest DPD4210 42 in. HD-Ready Plasma Television Logo
sue reid Posted on Mar 20, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hyundai 42inch plasma tv
I have got 2 or3 1inch thick black lines running top to bottom of screen since the screen got slightly knocked
  • 2 more comments
  • Anonymous Dec 11, 2007
    when i turn my tv on plasma there are lines going up and down the screen like 8 or 9 and the pic shows blurry , wobble type.
  • rodsanders May 08, 2008
    have the exact same plasma with the same problem. have black line about 2 inches wide running from top to bottom of screen.always in exact same position. this line was coming and going but seems to be coming more frequent. can anyone tell me whether this is fixable and what sort of cost i might be looking at.
  • omrgcw Jul 22, 2008
    i got the same problem
  • tkyleq Jul 22, 2008
    I have a black rectangle, 3 inches wide, half screen height, on the top half of the screen. Looks bad, will not go away, no matter what. Ideas?
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 16, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
7064
Points
8
Had the same problem.  Was quoted $800 to fix.  Searched the internet for 6 months and found this thread on avforums.com
http://www.avforums.com/forums/showthread.php?t=462873&highlight=black+line+on+plasma&page=4
Read through all the posts.  Very simple fix, but you have to have some mechanical inclinations or you can cause more problems than you started with.  I was up to 5 of the black lines, but decided to attempt the soldering these guys did and fixed it all for the cost of a soldering iron!  Even if you decide not to attempt it, it gives you somewhere to start to tell a technician.
Anonymous
Level 2:
Scholar:
  • Expert 124 Answers
  • Posted on Mar 20, 2006
Anonymous
Expert
Level 2:
Scholar:
Answers
124
Questions
0
Helped
255568
Points
240
If these are thick black lines, this is most likely line frequency noise entering the set. you may have a leakage from the DC ground on the secondary side of the powersupply to the AC side, or a bad filter capacitor(s). Most of the time it is the filter caps that give these types of problems. If you are connected to cable TV service, or an outside antenna you can also have this problem from an AC ground loop return. Also if there is a device such as a VCR connected to the TV and it has problems, it can cause this as well...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 23, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4561
Points
Have got 2 or3 1inch thick black lines running top to bottom of screen how do i get rid of the black line
  • Anonymous Jan 23, 2007
    how do i get rid of it
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 30 Answers
  • Posted on Oct 30, 2010
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
30
Questions
Helped
18738
Points
34
Hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 19, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6519
Points
Did anyone find a solution for this problem? I have the same TV and it has a single black line down the middle of the screen.
  • Anonymous Jan 29, 2007
    Hi
    Have a look here. I have found the problem with mine and it took all of an hour to fix at no cost.
    Suggest you dont throw these away but throw them in my dircetion :)
    http://www.fixya.com/support/t129859-30m...
Anonymous
Level 1:
  • Posted on Nov 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4561
Points
My too, did you figure out the problem? I just have one 1" thick fuzzy black stripe from top to bottom that is not pefectly straight.
Brian
Anonymous
Level 2:
Sniper:
  • Expert 80 Answers
  • Posted on Feb 12, 2007
Anonymous
Expert
Level 2:
Sniper:
Answers
80
Questions
Helped
118959
Points
165
If this set has impact damage, chances are the panel is damaged. The FPC cables connecting the panel may have connection issues as well, this would be repairable, replacing the panel itself is not economical. Joe Weibel
3 Related Answers
Anonymous
SOURCE: 30mm. vertical black line on screen.
Hi I have just fixed this problem on my screen. The fault was a dry solder joint on the driver circuit of the screen. Have a look at my thread here. I have tried to explain it as well as possible. Hope it helps.
dennis
  • 79 Answers
  • Posted on Aug 27, 2007
SOURCE: plasma
Hi , This is a common fault and easily fixed ,Ive posted some stuff under the hyundai 4240 section, 3 inch black lines , Please go through all the posts as there are links to photos to help you along , Tip , Use a digital camera for log you process so you know where all the screws and cables go , also , lift the brown strip upwards and slide the ribbon cable out ,and do the repair to them all..you understand once you read all the links
dennis
  • 79 Answers
  • Posted on Oct 22, 2008
SOURCE: hyundai plasma
go here and watch part one and two
http://www.youtube.com/watch?v=9NPobj0_GSo
Samsung TV thick black line running across the bottom.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
8helpful
I have an lg 42inch plasma and now a vertical black line running down centre of screen about 2 inch thick
I had the same problem with a five year old 50" LG Plasma. I fixed the problem with a 11 dollar soldering iron from Radio Shack and about 2 hours of my night. You have to open the back of the tv and locate where the ribbon strips are attached to the screen. I beleive that on your 42" they will be on the bottom of the tv. Mine had 11 on top and 11 on bottom. Yours will probably have around 7 or 8 along the bottom. Mine was a little easier since I did not have to remove the control board. You unfortunately probably will have to remove it. It is not hard at all, just takes more time. Make sure to keep your screws seperated and remember where everything goes. On bigger jobs some tape and a marker are very useful. Put tape on the board and around the wires removed and leave a tail. This way tou will remember to hook them all back up. Once you find the ribbon strips you have to remove them one by one and look at what is behind the metal place. There will be 4 capacitors and 4 resistors. The tv manufacturers want you to buy new tv's every 5 to 10 years so they use a very cheap solder on their contacts. Use you soldering iron and re-heat the solder to liquify it again and thats it. Allow time to cool on each of the caps and resistors. It took me about 1 to 2 seconds on each side of these parts. I did use a dual wattage soldering iron from radio shack. Its is a 25 and 35 watt iron. I used the higher setting. I have pictures if you would like me to email them to you and show you what I did. Be careful removing the ribbon strips, I broke one of the clips that hold in the ribbon strip. That is costing me an extra 25 dollars off ebay but still for a free tv, its not bad.
3helpful
2answers
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
2helpful
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Black line on plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
7helpful
2answers
Techwood TWP4210 Plasma tv
a resistor has developed a dry joint or failed on the data connectors of the plasma panel,there are eight at the top of the plasma. An easy fix if you know what youa are doing,
2answers
Black lines on plasma
The matrix controler or the matrix drive area is failing. The fix is to change the proper circuit boards, and then do the factory setup to match the board is necessary. In the worse case, it may be the display screen itself that has a failure occuring.
You will have to bring the set for factory service to have the work done. If the set is out of warranty, it may be expensive to service.
Jerry G.
1helpful
4answers
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
2helpful
4answers
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Top Hyundai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
