What a coincidence, I have a car radio too!
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
SOURCE: Pyramid SE301-VL amp wiring confusion...
Captain_Bill,
Red - should be fused & is the +12Vdc system supply voltage.
Chassis = System ground.
Individual Green, Grey, & cooresponding blacks will be the right & left chan Audio ins (Black = neg).
Paired bl/blwh, br/brwh, grey/grwh, & green/grwh will be the audio outs.
Hope this helps !!!!
Dale EE
SOURCE: wiring a pyramid 903G
red - power
Black - Ground
Blue/Black - rear Left Speaker Positive
Blue - Rear Left Speaker Neg
White/ Black - Front Left Speaker Positive
White - Front Left Speaker Neg
Brown/Black - Rear Right Speaker Positive
Brown - Rear Right Speaker Neg
Yellow/Black - Front Right Speaker Positive
Yellow - Front Right Speaker neg
Green - Left Input Positive
Green/White Left input Neg
Gray Right Input Positive
Gray/White - Right input Neg
SOURCE: installing pyramid 795cd equalizer
cd player or dvd player output------------to equalizer input---------equalizer output---------amplifier input--------amplifier output ----------to speakers
SOURCE: i have two pyramid MV7SC 7.2 in. car monitors. I
go to say Radio Shack and purchace some Multi cored, (4 -6 core) Co-axial cable, this means you have 4 - 6 "Conductors" and use the shield for all the earths & negative power,. This will give you what you need. At a pinch, you could always get a single core, audio coax, and run 4 of them and tape, or zippy tie, into a bundle.
SOURCE: I have a Pyramid 403G, no wiring diagram
I have the manual for the Pyramid 403G 7 band Graphic Equalizer. The wires To your radio: Green/white left negative Green left positive To your radio: Gray/white right negative Gray right positive Red with fuse to ignition power Black Ground Left Rear speakers: Blue rear left negative Blue/black left positive Left Front speakers: White/black left front positive White left front negative Right Rear speakers: Brown/black right rear positive Brown right rear negative Right Front speaker: Yellow/black right front positive Yellow right front
the wires are marked exactly the opposite of what all know as standard. According to the manual the wires marked with the black are positive, it threw me since I have been wiring for the last 25 years. If you make the mistake of wiring it like you wire everything else it will not have any power and act odd, I made that mistake.
