Your machine is having a problem that is power related.
First,
remove the machine's power cord from the wall, wait for about 30mins,
then plug it back in. If it still doesn't power on, then it is surely
having a power problem.
When electric current comes from
the power outlet into the machine, it goes straight into the power
supply board which then circulates the current into the machine. So if
the machine doesn't work, then there is a shot on
the power supply board.
If any machine or
electronics device behaves this way, it means its having a power
problem. it might have worked fine in the past, but that's electronics
for you. Power surge, irregular power supply, excess power supply, etc
can affect the unit thereby not making it to power on.
This
unit must have a power supply board in it where power enters from the
mains. A capacitor, fuse, diode, etc may have been defective on the
power board and maybe that's why its not making the unit turn on. There
might also be some disconnection or something, inside the unit which is
To actually
find out what's wrong, you need to disassemble the unit with a screw
driver and check what's wrong. You will be needing a meter and
continuity tester in order to read the components on the power board,
once you detect any bad component, you can make necessary replacement at
any electronics accessories store withing our vicinity. This is the
only way by which you can detect the problem.
Of
course, testing the power board with a meter will require someone that
has the ability. So it you can't, then you might be needing the help of a
repairman or you can call a friend that has the ability to help you
out.
I wish you the best of luck.
Regards.
