Keeps displaying F and H
Ckd for drain hose to low ..top needs to be 30-38 ins from floor also needs to be loose fitting in drain pipe to prevent siphoning ..if neither is the case ckd fill hoses for obstruction in screens last ch flow meter ..remove top round object left side with small hose from fill valve 1 side other side to detergent dispenser may try tapping it while it fills if works ok replace flowmeter
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
thankyou for responding but i am not that mechanical minded . i am a women ha ha .
