SOURCE: minn kota problem
Hello Jim. You have lost your power some where. Start with the wire & terminal connections to the battery. Open the bottom of the foot pedal and check the wiring connections there. Note be very careful here for you have the battery still connected. You may have a fuse in line some where blown. You can check for voltage with a VOM(volt meter) on the wire terminals. Good Luck.
SOURCE: Removing Prop
There should be a retainer nut accessible at the rear of the prop (in the center of the prop. Remove this and the prop should slide off.
SOURCE: Where can i get a circuit board for my minn kota
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
SOURCE: Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
SOURCE: How do you program extra Minn Kota® CoPilot Replacement Transmitters?
According to my user manual
To learn the ID number of additional remotes, follow these steps:
1.) Press and hold the LEARN button located on the side of the receiver (receiver will emit a continuous tone). A small blunt object must be used to depress the LEARN button (pen or screwdriver).
1.) Press any button on the remote (receiver will beep 4 times confirming that it has "learned" the ID number of the remote and that the programming is valid and complete).
