There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
There
The
going bad...
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
Could be a number of issues really. Motor is what I have found to be a problem, the start windings work, but the run windings wont. Also it could be a timer causing the problems as well. Both of these cost a bit of money to replace. Be sure to check the door switch (not usually a problem), buit check it to be sure. Let me know what you find out, but sure sounds like a motor issue. If I come up with any other ideas, I will write them right to you. Jim
PS Also try and check all your wiring inside to be sure something hadn't come loose. Forgot about the whole moving thing. Let me know if I can help you with anything else, like getting into the cabinet, etc. Jim
