Hello Mike - Typically, if the water temperature combination is not appropriate for the cycle selected, the status lights will blink and signal will beep 3 times. Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to beep. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
