Seems like the card has become corrupt. There is one thing you could do before replacing the card. SD cards have a small yellow switch with a sign to 'lock' the card. Make sure that the switch is not in the 'lock' position. Then clean the contacts with a pencil eraser and try to access or format the card again. If it fails to solve the issue, then try using another memory card.
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
I had a similar issue with an XD card in my Fuji FinePix S3000.
I had used the several times for a couple of years without problem.
The issue appeared right after dowloading pictures from the card inserted in my notebooks' card reader - an operation I have done several times in the same notebook without any problem.
I have fixed the issue going to Menu, Option, SetUp, Format and choosed OK.
Deleted all the pictures (make a copy before if the card is readable in the pc as it was my case) but made the card readable again.
