Tools & Materials required : - Mxkey Dongle with latest software installed
- UFS / JAF Box
- Nokia 5130c Fbus cable
- CA-101 Usb data Cable
Step By Step :- Open Mxkey Software
- Select UFS / JAF as Interface, then connect it.
- Pick Nokia Module
- Pick BB5 Tab
- Pick Service Tab
- Connect Phone to UFS / JAF box using Nokia 5130c Fbus Cable
- Click on " backup RPL "
- Save to safe location.
- Pick PM Tab, read full, save to safe location.
- Flashing / Firmware Updating via CA-101 Usb data cable
- Select Nokia Usb Rom as Interface
- Pick Nokia Module
- Pick BB5 Tab
- On flashng Tab, Pick Nokia 5130c Latest Firmware Package Properly.
- Click on " Flash " Tab
- Connect Phone to PC via CA-101 Usb data cable.
- Wait Until All Process done
Here's the log operations : Reading phone`s ID ...
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
productData saved.
Restarting phone ...
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 24E0000D70D27D5657572DFFD11A84578F44242B
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Reading RAP NPC (0x168 bytes).
Reading RAP VARIANT (0x0 bytes).
Reading RAP CCC (0x160 bytes).
Reading RAP HWC (0xD4 bytes).
Flash Imei: 35422303116811
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:mobileEx.4dataackupRPLBB5_35xxxxxxxxx_BACK.rpl"
Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010)
Processing file: rm495__07.97.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsucNokia USB Flashing Generic, ID: 1FB998E3
RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
RAP EM0 ID: 00000296
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 24E0000D70D27D5657572DFFD11A84578F44242B
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes
[ADL] Device found: nmwcdnsucNokia BB5 ADL Loader USB Generic, ID: 8572D57
[ADL] Verifying communication to device OK.
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.500 s
CMT NOR area [000006C0-0001FFFF] erased in 0.515 s
CMT NOR area [00040000-000BFFFF] erased in 2.172 s
CMT NOR area [000C0000-0013FFFF] erased in 2.094 s
CMT NOR area [00140000-0137FFFF] erased in 1 min 17.812 s
CMT NOR area [01380000-0151FFFF] erased in 6.954 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 1 min 5.172 s
Processing file: rm495__07.97.ppm_x as PPM
[BB5,BB5 ALGORITHM] size: 7.72 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 37.188 s
Programming completed in 26.469 s
Processing file: rm495__07.97.image_x_red as CNT
[BB5,BB5 ALGORITHM] page size: 128 K size: 12.89 MB
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF] erased in 22.829 s
CMT NOR area [02160000-03FBFFFF] erased in 3 min 12.922 s
Programming completed in 45.125 s
[ADL] Restarting phone ...
[ADL] Device found: nmwcdcNokia 5130 XPressMusic USB Generic, ID: 1878DB02
Flashing completed in 9 min 5.000 s
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 3542xxxxxxxxxxx
Product Code: 0578115
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354xxxxxxxxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 9 min 8.922 s
