What is the problem if motherboard goes on but for a short while than goes off....and I suspect that it gets hot
  • LTFubar
    LTFubar Aug 29, 2011
    short ? as 20 seconds or 20 minutes?
    Habit-Forming:
  • 73 Answers
This could be a heat issue. If the pc is a desktop, try running it with the case open and randomely feeling the heat sink to make sure it is not getting incredibly hot. It will get hot, but not usually hot enough to burn you, if it does, then you have a heat issue and your fan is not turning at the speeds it should be, or your heat sink might be full of dust, etc.
Also if the heat sink stays within good temps but the pc still kicks off, It may be your power supply, In that case I recommend purchasing one from geeks.com, any of the logisys power supplies seem to be pretty good from my experience. A logisys psup is typically around $24-28 before shipping. This only applies if your pc is a standard desktop, If its a mini or a laptop these power supplies won't fit.
Kris
Posted on Aug 29, 2011
  • Computers & ... Master
  • 27,725 Answers
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
hope this helps you
6ya staff
SOURCE:
Batteries Hot
This sound to me that an electrolytic capacitor has given up and went short circuit especially tantalums it can be a transistor or I.C. but I doubt it
Mar 01, 2014 | Sennheiser 100/500 G2 Series Wireless...
I suspect my power supply is going bad. when i turn on pc all i get is fans running and green light is constant.monitor goes into standby within couple seconds and hard drive amber light goes out in...
Not being an electronics expert i would have to say this is bad, and not your power supply but your entire motherboard. The only times i have seen this with these problems the fix was a new motherboard. The hot glue is fluid from the capacitors when they overheated and blew up. But somebody else out there might now more then me about electronics so maybe they will have a different answer. sorry.
Nov 04, 2013 | Compaq Evo D510 Minitower (Open Box)...
Dryer doesn't get hot. It will ignite, get warm then goes cold
I would suspect the valve coils. they will work for a short time and then fail, cool off and work again. very easy to replace.
Jun 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Would not boot Processor pins appear undamaged
  • Check for shorts and overloads inside computer by removing nonessential items such as extra controller cards and IDE/ATAPI devices and turning the computer on to see if it starts to boot. Leave the motherboard, power supply, RAM or processor. If the problem goes away, there was a short or overload with one of the components that you just removed or one of those components is faulty. Replace each of those one at a time until you isolate which is causing the problem. If the problem still occurs after removing the nonessential components, the problem has to be with the motherboard, power supply, RAM or processor.
  • Remove the processor and RAM and reinstall them to make sure that they are installed correctly.
  • If the problem still persists, swap the RAM with known good RAM. In addition, test the suspected RAM in another known working system.
  • If the problem still persists, swap the processor with a known good processor. In addition, test the suspected processor in another known working system.
  • If the problem still persists, swap the motherboard with a known good motherboard. In addition, test the suspected motherboard in another known working system.
  • Feb 25, 2010 | Computers & Internet
    1996 cavalier hesitates randomly then will work fine again???
    sounds more like the coil packs are shorting out when they get hot.
    Nov 29, 2009 | 1996 Chevrolet Cavalier
    The computer does not start.the problem is that when i press the start button,the,comp starts for a few seconds i.e fan revolves,led light indicates,makes a sound like its having a short circuit the goes...
    The first thing I would suspect is a faulty power supply.
    If it were in my shop, I'd replace the power supply--is seems that you are not even seeing the operating system and most likely it's not having the opportunity to actually complete it's POST.
    Oct 22, 2009 | Mercury KVM266PM-U (KVM266PMUD1600)...
    Toshiba Satellite M65-S821 WONT BOOT UP
    probably shorted out motherboard. same happened to mine. motherboard alone is over $300 plus
    labor.
    Nov 07, 2008 | Toshiba A205-S4577 Notebook
    Whirlpool dryer the heating element will not shut off. I suspect a thermal fuse but took them in and they said they were okay. I am going to check and see if the element goes to ground on the case as...
    There have been many cases in recent months where the heater coil is shorting to the case. In many cases, this issue will only appear when the heater gets hot. If the dryer is getting hot when not running, replace the heater even if it appears good when cooled down. You received good recommendation....
    If you need further assistance, let me know
    Regards,
    reg501
    Jul 07, 2008 | Whirlpool Dryers
    Does not power up
    I think you've done a good trouble shooting job, and proved that the board is dead.
    Oct 20, 2007 | Asrock K7VT2 Motherboard
    Computers & Internet Logo
    Ekse
    Marvin
    Marvin
