I think bulb on my Panasonic finally bit the dust. How can I be sure. The bulb indicator light blinks on the front of the unit. According to the manual and blogs I've read, the bulb indicator light should be solid if the bulb needs replaced.
Take the bulb out, there should be a access panel in the front, power the set on,(be sure to have the lamp door closed) if you hear a rapid ticking noise from the set, the Ballast is trying to fire the lamp, this is a good indication that the set is functional but the lamp needs to be replaced. If not, the ballast is not getting the voltage needed to start the lamp.
Your Balister is shot. google balister on this model, or save yourself some time, stick it in a corner as a giant paper weight as I did and file a complaint with conumer affairs, they are online. Heath
