SOURCE: ERROR CODE 7410:0004729
Hi, switch off printer ,just open cover(door) on the left side of the machine and push Drum Unit in machine(to proper seat)
You have to hear "click" sound.Switch on printer.
Regards...
SOURCE: CALL SERVICE 7410:0002988
the 7410 error may be a drum unit that is not pushed in properly or it could be the following
defective drum EEPROM drum needs to be replaced or
defective engine PCB
the above suggestions assume that it is an original Kyocera drum
hope it helps
SOURCE: Kyocera FS-4000DN, CALL SERVICE 6030:0159631
this error indicates a problem with the fuser unit.
if you are an end user, you will have to check warranty status with you nearest service agent and have the fuser replaced free or get a quotation if it is out of warranty
SOURCE: LCD Displays "Call Service 7410:0089745"
This is a Drum unit non-installing error: drum is not installed or not installed properly. The durm PWB EEPROM does not communicate nor mally. Defective connection drum PWB(YC1) and Connect-L PWB(YC3). Maybe defective drum PWB EEPROM or defective engine PWB or itis just the drum unit itself is defective.
SOURCE: Kyocera FS-4000DN Laser Printer call for service
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
