Hi.
SY: Defective evaporator system. Check evaporator fan, thermostat and heater.
EF: Evaporator Fan defective. Test and eventually replace the evaporator fan.
The problem is likely the evaporator fan. Before replacing the fan test the other parts comprised in the evaporator system.
Here a tip explaining how to test such parts with a similar fridge model: Fridge not cooling. Procedure is more or less the same with your model.
Here parts and diagrams for your model.
Generally you can find parts and diagrams for most appliances using the links listed on this page: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Hello Angela Clark - Typically error code SY CF indicates that the refrigerator has detected a communication failure after power up. Contact a professional to move forward accurately. The wiring between the main control board and user interface board will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
