Hi Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. However most importantly eliminate the oven sensor plug at the back of the range and hardwire it using a high temperature porcelain wire nuts. Then locate the sensor plug at the control board and measure the sensor resistance. It is supposed to be about 1100 Ohms at the room temperature. Make sure there is a good connection between this plug and the control board. Please get back to us if you have further query or else please accept the solution.
Also try to reset it by unplugging the oven and put it back after 30 minutes or .If the fan is not stopping then it is probably a wire that has a bad connection and feeds it with electricity when it's not supposed to. Probably the isolation went off from the heat and in this case you need to call a repair person to get it diagnosed.
