HP CB350 Digital Camera Logo
Posted on Aug 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shutter lense is stuck out, want retract. Display went black. want retract and display is black.
Anonymous
Level 2:
Sergeant:
  • Expert 304 Answers
  • Posted on Aug 29, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
304
Questions
0
Helped
52278
Points
858
Hi, It sounds like the lens is stuck, possibly from dropping? Either way if lighting tapping it doesn't work then unfortunately there's no way it can be fixed.
My screen is black and will not display images to shoot. Also when picture is taken it plays back as black image. Previously taken pictures will display.
Michele, a stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
I cannot see anything out of my camera, the display is black. It is like the lense cap is on.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
2helpful
I dropped my camera and since then I can take photos, the camera focuses, my display is fine when viewing previously shot images and the normal display information but when the shutter is pressed all o see...
When you take off the lens and fire off a shot, does the mirror go up and return or does it stay up? If not, is it possible that it is staying up when the lens is connected? When you fire a shot, can you hear it returning?
3helpful
2answers
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
2helpful
Camera works but the screen went black A640 except for video and color swap. Did I press a button? I was shooting in cold weather.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
But if you've already tried this, have you also tried downloading any of your photos taken with the black screen to your computer? Are the photos also black? If so, you might instead be experieincing a stuck shutter (possibly due to the cold weather).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
No lcd display and no pictures
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Protective lense shutter is stuck partially closed, causing black corners in the photos. How do I fix this, or remove the shutter completely?
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But for the A610, you might want to extend your zoom all the way out before removing the camera's batteries. Note that the A610 has four shutter leaves instead of two, so pay particular attention how they're assembled if you remove the lens ring. Also you'll be applying the ring loosening rubbing alcohol around the barrel's perimeter instead of the front as shown in the procedures. One other thing, try not to get any alcohol on the lens itself:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Good luck, and remember to do this only as a very last resort (try the other listed procedures first). Oh, and if you do decide to try the repair, please post how it went.
Canon A620, I can review pictures taken, func set and menu, but I can't see what the lense sees.
Are you able to take pictures with the shutter button, and do the pictures come out OK? If so then it's likely that you accidentally pressed the DISP button on the back of your camera. Press it once more to turn your display back on.
But if the pictures are also coming out black like the display, then the problem is more serious, and is likely a stuck shutter (this cannot be repaired by the average person). This would require professional repair. Call 1-800-OK-CANON to arrange repair.
My camera's display is black when I try to take a picture, and all the pictures I take are all black. How do I fix this problem?
Your digital signal processor is bad or your lense shutter is stuck on the inside. A stuck lense can be fixed by replacing the lense barrel. Check out Camera Shy Anna on Ebay stores. They can fix your digital camera.
Nov 25, 2008 • Cameras
1helpful
Broken camera
Hiya
Few quick things.
Digital camera need to initialize when you switch them on. Rather like booting a computer, they need to get themselves ready for work....
It sounds like yours is stuck in a position where it has gone beyond the bit where it is told to get ready, so it sits there waiting to be told :-(
When cameras get a thump, sometimes the mechanism can be knocked into a position that it was never designed for.
Firstly, look at the lense. Check that it has not extended slightly further than it should have. If it has the small servo motor that drives it may not engage correctly. With the power on, you could try gently applying pressure to the front of the lense (not the glass), to see if you can persuade it to retract. If it does retract, it will probably work.
Next, the lense may have been knocked slightly out of line, use the same process as above.
Have a look down the lense from the front of the camera. Can you see the shutter? This is black in colour and should closed. If it is half open use a cotton bud to move it slightly and see if that is enough to get things moving again.
Finally, you could try removing the battery/batteries, leave them out of the camera for two minutes then reinsert them and try again.
Good luck..
Feb 14, 2008 • Cameras
Top HP Cameras Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a HP Camera Expert? Answer questions, earn points and help others
