2006 Touring shocks =
Table 2-6. Rear Air Suspension Pressures
Shock Loading Recommended Pressures
PSI kPa
All Models Except FLHRS, FLHX - Standard Shocks
Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
FLHRS, FLHX Only - Low Profile Shocks
Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
Solo rider over 200 lbs. (91 kg) 5-10 35-69
Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
111WWAARRNNININGG
Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
SOURCE: how much air should be in the front shocks?
too much pressure an yul blow rings in shocks call dealer for proper pressure
SOURCE: I need the air pressure reading front front shock
Not sure of the pressure i do now its not much 4psi?, too much and you burst the seals, and use a bicycle pump and digtal tire gauge not a airline and compresor, some even recommend Nitrogoen..
SOURCE: what is the air pressure for the rear shock 2008
here is the table according to h-d a solo rider up 150 lbs. is 0 psi, 150-200 lbs is 0-10 psi, 200-250 is 5-15 psi,with passenger and rider up to 150 lbs is 10-15 psi,up to 200 lbs is20-25 psi, max weight is 20-35 psi good luck ride safely
