I Will Be Facing canon Ir 3100cn Printer Problem .The Problem Is error Cod Is Pls Switch the Power On Or Off Buttan And Coad Is e000014-0001
Pls Solve This Problem And Guaid Me .....................Thanks Sir
When 'E000'is indicated, the NVRAM on the DC controller PCB remembers an error in thefixing assembly even when the power switch is turned off and then on. Afterturning on the power, be sure to execute the following in service mode (Toenter service mode *and # then go to clear) to remove the error information:
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn
...imaging drum cartridge. Turn the
printer off using the power switch on the left side. Wait 10 seconds,
turn the printer back on, and check if the error message...sensor
solenoid nip. Turn the printer off using the power switch on the left...
(English)
016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn
... Press Select ( ) to clear the error on
the printer. Reset the printer NVRAM: Press Menu. Press the...and then
press Select ( ). When Restart Printer appears, turn the printer off and
then back on...
(English)
KB Article
How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059
...Troubleshooting Guide for My Dell
3000cn-series / 3100cn Laser Printer ...available online for your Dell
3000cn/3100cn laser printer. The troubleshooting...printing, refer to
the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide...
(English)
E732 Reader communication error 0001 DDI-S communication error Check on connection between the reader controller PCB and the main controller PCB, Check on the reader power supply
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to reach 70 deg C within 180 sec after reaching 50 deg C. Check on connection of the thermistor, Replace the fixing unit To recover from the error: In service mode ( * 2 8 * ) COPIER>FUNCTION>CLEAR >ERR 0003 The non-contact thermistor fails to reach 100 deg C within 180 sec after reaching 70 deg C. 0004 The non-contact thermistor fails to reach 120 deg C within 180 sec after reaching 100 deg C. 0005 The non-contact thermistor fails to reach 140 deg C within 180 sec after reaching 120 deg C. 0006 The non-contact thermistor fails to reach 160 deg C within 180 sec after reaching 140 deg C. 0007 The non-contact thermistor fails to reach 180 deg C within 180 sec after reaching 160 deg C. 0008 The non-contact thermistor fails to reach standby temperature (normally 190 deg C) within 180 sec after reaching 180 deg C. 0101 The non-contact thermistor fails to reach 120 deg C within 300 sec after power-on. 0102 The non-contact thermistor fails to reach standby temperature (normally 190 deg C) within 300 sec after reaching 120 deg C.
