LG 37LC7D 37 in. LCD HDTV Logo
Posted on Sep 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing display back to widescreen
I have a problem where the picture no longer extends to the outside edges of the tv and it leaves black surround on the right and left side of the screen. What do i need to press to fix this problem?
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Sep 10, 2008
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564452
Points
12312
There should be a menu option for "aspect ratio" somewhere. The old standard was 4:3. The new is what was colled "wide screen" and is 16:9. I believe that this is under the video setup menu.
Dan
  • mrhppy45 Aug 15, 2011
    Pictures change between 4:3 and 16:9 without warning. How can I reverse this please?
1helpful
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
1helpful
SHARP AQUOS 46INCH CANT GET A FULL PICTURE ONLY IF I USE ZOOM WILL THE SCREENBE FULL
Hi Anthony,
You're describing what is called letterbox and pillerbox. Letterboxing is when there are two horizontal bars - one at the top and one at the bottom of the screen with a wide picture between. Pillerbox is when there are two vertical bars - one on the left edge and one on the right edge of the screen with a tall picture between.
The settings on your TV (and on your cable box, satellite box, DVD player, etc.) tell the TV how to display a picture that will not fill the screen completely. If the program source (an older video-taped TV show, non-widescreen version DVD, etc) was not originally "shot" or saved in widescreen format, the TV offers you a choice on how to display the image. They ask if they should stretch or zoom to fill the screen (and you have to deal with the skinny / tall images or lost portions of the picture); or maintain the aspect ratio (not stretching or zooming) by leaving a part of the screen blank (grey or black) by inserting bars left and right or top and bottom of the screen.
Start out by telling the devices that send pictures in a format that matches you TV's screen ratio. I am assuming you've got a wide screen HDTV which would mean it should be set to "16 x 9" (a.k.a. 16:9) ratio display. If you have it set for 4 x 3 (a.k.a. 4:3) you should change it. Look for a setting on your TV that asks about stretching, zooming, etc. as this will be an issue when receiving picture from an off air antenna on your house when a TV station is airing an older, non-wide screen format TV show or movie.
TV signals provided by Cable TV or Satellite provider must be HDTV type signals. If you have the standard TV service (non-HD) no picture sent by them will ever fill the screen. This is because Standard Definition TV (SDTV) is not capable of those types of signals. You will have to bump up your subscription to HDTV service to get full screen pictures.
I hope this helps!
The TV picture is outside the screen e.g. the top of the newsreaders head is missing. I've tried changed in the picture type, from widescreen to movie expand 14:9 on to 4:3, superzoom gives the best result...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
1helpful
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
2helpful
Invalid format displays on screen
hello try changing the picture ratio...what i mean is try 16.9 widescreen or 4.3 ledder box the tv is tryn to produce a pic bigger or smaller than what you have keep tryn different picture ratio's
I have a TX32PM11C 32"
You have to turn off the "automatic", so the TV will not automatically show you what it wants you to see. Then, if you select 16:9 , you will see true widescreen.
Since you cannot physically change the size or shape of your TV, the picture itself will be black on the top and bottom. Since not all programs are widescreen, sometimes the sides will be black. You can try the other sizes to see which works best for you.
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
50 INCH HITACHI ULTRAVISION HAS COLOR DIFFERENCE ON EDGE OF SCREEN
Hey, I found this on a blogsite about lcd rear projections....looks like our tv's screens have been burned by the "pillers" that surround the tv when switching from 4:3 to 16:9 or fullscreen... read below, I hope it helps !
cheers!
Vern
Rear projection crt's,the first generation widescreen tv's were notorious for that.Lcd and plasma can have the same problem,but it takes much longer and is not as harsh.Dlp's use tiny mirrors,so it isn't a problem with them.Lcd and plasma tv's should be ok unless you watch them with blck bars on them all the time.
We have lcd monitors at work,and i've seen them after a year with bad burn in.They also run 24 hrs a day 7 days a week with the same display.
GKar posted 2006 Oct 10 15:31 TooLFooL : i have 51" sony rear-projection and those freakin' grey bars burned themselves right into the screen...
I read that to avoid the burning you had to limit your 4:3 viewing time to 15% of total time viewed. (applied to my TV but apparently yours and others as well...great! now they tell you :-x , this applies unless 4:3 aspect was changed to stretched or zoomed...yuck :-x )
This really sucks as a Star Trek/Lexx/Farscape fan as they are mostly 4:3, fortunately the upconvert player/hdmi combo sends a 1080i 16:9 signal to my TV so the effects are drastically reduced by nearly filling the TV without the grey bars or burn in problem without stretch or zoom modes being used. yay! :wink: (default grey bars set to black automatically, apparently grey isn't needed due to screen area covered is sufficient for burn in not to be a problem.)
2helpful
2answers
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
