How to
import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Final Cut Pro is a professional and all in one video editing, compositing and special effects package for the Macintosh. The software logs and captures video onto a hard drive (internal or external), where it can be edited and processed.
If you are a Kodak video fan and you want to give professional editing to your Kodak videos, Final Cut Pro is the best choice for you. However, Final Cut Pro can edit any QuickTime compatible file format including DV, HDV, MOV, MPEG-4. That is to say, in order to edit your Kodak video with Final Cut Pro, you have to convert Kodak videos to the supported formats by Final Cut Pro with Kodak video to Final Cut Pro Converter for Mac.
Tips:
Kodak records the video files with mov files (i.e. Quicktime files) does not mean they are perfect for editing in FCP. The fact is, all of the small video cams, including the Kodak Zi8 Cams, records highly compressed codecs that are known as delivery codecs, not editing codecs. You need one third-party software to convert HD mov files to some formats like DV, HDV , MPEG-4 that FCP is happy to edit.
How to import Kodak video to Final Cut Pro and
Kodak video to Final Cut Pro Converter for Mac is one simple-to-use solution with the minimum amount of buttons and a small menu for converting Kodak video (Kodak Zx1, Kodak zi6, Kodak Zi8 and Kodak PLAYSPORT) to DV, HDV, MPEG-4, etc., for importing Kodak videos to Final Cut Pro. Besides, it is also an easy-to-use editing tool that assist you for making personalized video. You can trim the video to a certain length to convert, adjust video aspect ration by using crop function, add special effect like Gray, Emboss, Old film into video to make it more artistic, join several files or set the video output parameters. All this can be done with a few mouse clicks.
Part one: How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Step 1:Free download and install Mac Kodak video to Final Cut Pro Converter
Download Kodak Video to Final Cut Pro Converter For Mac and double click the downloaded . dmg files to install. A user-friendly interface will pop up.
Step 2:Load Kodak video files
First: Connect Kodak camcorder to computer and transfer mov files to iMac, Mac book.
Second: Hit the File button on the top left panel or click "Add Video" button to select Kodak MOV files to this converter.
Step 3:Select the output format and destination
Click the downward arrow beside Settings to choose the proper Final Cut Pro format from the drop-down list. And then click Browse button to specify the output location.
Tips: Select DV, HDV or MOV format for FCP in the pull-up list next to Profile field. And then click Browse button to specify the output location.
Step 4:Start the conversion
After all the necessary setting has been done, hit the "Start" button to start converting. Click the Open button to select the converted DV, HDV files to Final Cut Pro for further editing upon completion.
Part Two: Import Kodak videos to Final Cut Pro and edit Kodak video in Final Cut Pro.
Step 1:Import Kodak videos to Final Cut Pro
Launch Final Cut Pro and click "Import"-"Files" and then select the converted Kodak files. Find the file in the resources list for the project and drag the file into the Timeline, and then save the project.
Step 2:Edit Kodak video in Final Cut Pro
Apple's Final Cut Pro Software is an all in one video editing, compositing, and special effects package for the Macintosh. The following steps will show you how to use the Timeline:
One: Edit video and audio timing
There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place.
Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other.
Two: Add transitions
For Kodak videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Three: Export video
Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
learn
