SOURCE: Palmcorder playback question
Use the RCA cables that come with the Palmcorder® to connect the Palmcorder® from "A/V out" to "A/V in" on the VCR. Then change the VCR to line mode.
SOURCE: Acts like it's reconrding, then won't play back. Plays back older tapes with difficulty
You have one of two problems my freind. One could be the CCD sensor or related circuits have a problem in it and most likly a bad capacitor or a CCD imager, or the shutter is bad and sticking. Unfortanatly you really cannot tell untill the unit is taken apart and bench yested. I found a few really reliable folks that will give you a free estamate as I have sent a few peeps to them in the past and with great results. Good Luck http://www.videoonerepair.com/ Or http://www.videotech.com/ http://www.camcorderrepair.com/
SOURCE: Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
SOURCE: horizontal lines on playback screen
This sounds like the record heads on the camcorder are worn. The heads can be replaced however it would be considerably cheaper to buy a new camera
SOURCE: No Picture on playback
alignment is offset, should be easy fix with you local electronics repair place....if you need a cost estimate let me know model
What did you end up doing Shelly? I am now in the same boat - thinking of spending the money to have Costco do it!
