Make sure your battery isn't fully drained. Make sure your battery has at least 3.1 V. Anything above that is good. You can check this by using a voltmeter/multimeter
If the battery is OK, make sure both of your chargers are working. Both of them can be bad. You know, there is a posiblity.
If the chargers are fine and the battery is fine, it's probably a hardware fault. Hand it over to a repair shop
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
SOURCE: nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
SOURCE: Nokia 3600 not charging (it says "charger not supported")
I had the exact same problem. There is something wrong with the new charger, either the voltage or something... But when i changed to the old Nokia chager (same small pin) It worked. One can prob just deliver it back and get a new charger.
SOURCE: Unlocked Nokia 5310 doesn't turn on.
Maybe its your battery or charger port.Try to use another battery, if did'nt work then it's charger port.To avoid this kind of error please do not overcharged your phone.
SOURCE: charger not supported for nokia 3600s....Help please
Charger not supported for nokia 3600s....Help please
