2000 Jeep Grand Cherokee Stereo Wiring
Constant 12V+
Red/White
Switched 12V+
White/Red
Ground
Black
Illumination
n/a
Dimmer
Orange
Antenna
Right Front
Front Speakers
6" x 9" Doors
Left Front (+)
Light Green/Red
Left Front (-)
Light Green/Green
Right Front (+)
Light Blue/Red
Right Front (-)
Light Blue/Black
Rear Speakers
6 1/2" Rear Door
Left Rear (+)
Dark Green/White
Left Rear (-)
White/Dark Green
Right Rear (+)
White/Purple
Right Rear (-)
Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
RED-12VOLT
YELLOW-MEMORY 12VOLT
WHITE-FRONT LEFT+/WHITE WITH STRIPE-
GRAY-FRONT RIGHT+/GRAY WITH STRIPE-
GREEN REAR LEFT+/GREEN WITH STRIPE-
PURPLE REAR RIGHT+/PURPLE WITH STRIPE-
BROWN-MUTE
ORANGE-ILLUMANATION
BLUE-REMOTE(AKA)AMP TURN ON
BLACK-GROUND(NEG.)
RED-12VOLT
BROWN-MUTE
ORANGE-ILLUMANATION
BLACK-GROUND(NEG.)
Thanks and please do leave positve feedback and ratings for your free answer.
Could be that you have a partially roasted(blown) coil on one of your subs which will function- but will keep tripping your amp.You can check that out just by using a different set of subs to listen to and by the process of elimination if the problem goes away then you know where the problem is at.Also check your gains you might be riding the gain a little high which causes distortion which causes heat(FAST) which will cause the amp to shut down completely or some amps will decrease output in a programmed attempt to save itself.turn the bass boost down to half if you even use it at all- that too can cause massive distortion in the amp itself,meaning only that if you have the bass boost on your deck turned up and then you turn the boost up on your amp the sound signal is then WAYYY distorted which will cause a thermal shutdown too. Last thing is to make sure that your subs arent running below 2 ohms because i believe that particular amp is designed to put out about 900 watts at 2 ohms.good luck
Its hard to tell what you can or cant do without knowing exactly which kenwood amp you are using. Generally speaking though most kenwood amps are stable only down to 2 ohms. you will be better off just using 2 of your 12s wired in parallel- that will give you a 2 ohm load. There is a way to use all 3 simply by wiring them in series, it will end up giving you a 12 ohm load on the amp though which will work fine but you wont ever achieve the full power that the amp can do.
yes there will be a blue wire and maybe a blue with white wire one will give 12volt the whole time the radio is on, the other wire will give 12 volts for 10sec
yellow- 12volt
red- Ignition
black- ground
blue/white- remote (amp turn-on)
white and white/black- front left
gray and gray/black- front right
green and green/black- rear left
purple and purple/black- rear right
have you checked the remote wire is supply power? try jumping the main power wire t the remote wire to see if it turn on. Also check that your ground wire is securely making contact.
Try checking the fuse. If no fuse then you probably have some power supply problem. Be sure the ground is well connected to the car also. If all that is fine it sounds like there are some shorted power trasistors. I do amp repair faor a living also I'm the cheapest business youll find.
Let me know what you find out. Try disconecting your speakers.
12 VOLT FROM THE BATTERY SOURCE GOES TO 12VOLT BATT CONNECTION.12 VOLT GROUND RETURN MUST BE FIXED TO THE FRAME OF THE VEHICLE.SOME VEHICLES HAVE FACTORY GROUNDS UP HIGH ON THE SIDES OF MOST VEHICLES, U CAN USE THIS GROUND LOCATION. IF CONNECT REMOTE WIRE FROM THE RADIOS REMOTE TURN ON LEAD WHICH IS A BLUE/WHITE WIRE OR A STANDARD BLUE IF ITS JUST ONE BLUE WIRE. CONNECT THIS LEAD TO THE REMOTE TURN ON CONNECTION ON THE AMP , SOME KENWOODS HAVE TWO ,INPUT AND OUTPUT LEADS.U ALSO NEED A TEST LIGHT, OR U CAN USE A SPEAKER TO TEST FOR POWER AT UR CONNECTION.IF U USE A TEST LIGHT , CLAMP THE END U WOULD GROUND TO THE VEHICLE, TO THE AMPS GROUND, THEN TOUCH THE PROBE END OF THE TEST LIGHT TO UR WIRED CONNECTION TO VERIFY U HAVE POWER AND GROUND TO YOUR CONNECTION.IF TEST LIGHT DOESN'T WORK ,CHECK UR FUSE AND REMOTE TURN OR LEADS.
