Maintenance message means that you will need to order a maintenance kit for that printer. In a maintenance kit usually comes a new fuser core, transfer roller, and feed tires.
The fuser core is used to heat up the ink and permanently affix it to the paper before it comes out on the top tray.
If the printer still prints fine, and depending on how much printing you actually do on this, you may be able to get away with not needing to replace the maintenance kit for a couple more weeks.
1. Press the start key.
2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
