Toshiba Satelite 5205-S505 Notebook Logo
Posted on Sep 10, 2008
IMB R50e laptop intermittenley switches on
I have an IBM R50e laptop. It will only power up occasionally and sometimes does noting when I try to power it up. There are times when it starts ok, but while I am working on it, it frequently switches off without warning.
Any suggestion please.
Andy
Restore imb thinkpad r50 to factory setting
If the recovery partition on the hard drive is still on the hard disk then -
With the ThinkPad off, push the power button and the minute you see the startup screen push the F11 button, hold it for just a moment and release it. That will take you to the rescue and recovery application
What do i do if the restore afctory settings do not pop up on my ibm thinkpad laptop
Try this first ... You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
I have IBM R50e Celeron laptop, i want know whether it has wireless lan facility. I could see wireless sign on it.
If you see the wireless LED light glowing, the defenitely it will have the wireless facility. There might be a harware and a software switch for IBM Laptops. Hardware switch is on the left front panel of the Laptop. To find the software control of Wireless, Press Fn and F5 which will open up a Black window and you can switch ON or OFF the wireless.
Hope this helps. Good Luck ~SmokinJoe~
I have ibm R50e ... i insert the lan cable .. Light turns on but my network card .. Pci modem and many ither things are not installed and i can find the drivers not even on ibm site
Hi, Here you can find all the drivers for your computer: http://www-307.ibm.com/pc/support/site.wss/MIGR-55042.html
Please note that usually network card does not requires drivers for Ethernet port - Your network might eventually be defective if all drivers installed does not fix the issue.
6helpful
3answers
My laptop sound is not wrcking
www.opendrivers.com/driver/233753/ibm-thinkpad-r50e-audio-driver-v5.12.01.5410-windows-2000-xp-free-download.html
www.soft32download.com/software/IBM-ThinkPad-R50e-Audio-driver-download-details.html
try the above two links where you can download the driver
IBM thinkpad does not power up. Nephew watching
Could be the power button shorted, Does it operate when not plugged in?
The plug jack on the back where the pc would be plugged in, sometimes loosens and needs to be resoldered too. If the pc works when not plugged in, but does work on just the battery.
If no power on during either, it is probably the power on switch gone. Any lights whatsoever showing?
5helpful
Can i use DDR2-800 ram for ibm r50e pc notebook
Sorry, no. The R50e series uses only DDR laptop memory.
For determining memory options w/o even opening the PC, try:
http://www.crucial.com
...and run the memory scan.
4helpful
2answers
ACCESS IBM
you are missing the hot-key diver. For the thinkpad R50e, you can download it here
http://www-307.ibm.com/pc/support/site.wss/MIGR-55042.html#utility
IBM THINKPAD r50E
my problem is i dont have enternet controller driver and modem driver for my IBM R50e
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
