Question about Bosch 24 in. SGS66E02 Exxcel Built-in Dishwasher
Dishwasher tablets not dissolving
We have had our Bosch Exxcel dishwasher for 7 months, and have noticed that the machine is dissolving less and less of the dishwasher tablet until we are now finding the whole thing in the bottom of the dishwasher at the end of the cycle. Someone mentioned that it might be due to calcification from water hardness. We live in a hard water area, and I use water softeners in my washing machine, but I am not aware of water softeners for use in dishwashers - I always thought the salt took care of that.
  • 1 more comment
  • Anonymous May 17, 2009
  • Robbyn Bray
    Robbyn Bray Nov 18, 2017
    We’ve only had ours a few months it suddenly quit dissolving tablet. I believe it’s thermostat. I tried throwing it in the bottom of dishwasher still doesn’t dissolve.. I looked under sink drain hose is up high. Fortunately we are under warranty.
  • Esha Neogy
    Esha Neogy Sep 06, 2019
    In my case, the problem was that the little door didn't open properly to let the tablet out in good time. Running the rinse cycle (I think) with a bowl of vinegar in it removed the hard water deposit so the door could open. It doesn't sound like that's your problem, but I thought I'd mention it just in case. Good luck!
  • 3 Answers
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Posted on Aug 26, 2009
  • Anonymous Apr 13, 2019
    Parece que tudo est? bem feito. O programa ? selecionado corretamente, os pratos s?o carregados na m?quina por todas as regras, e o tablet n?o se dissolve na m?quina de lavar lou?a. E isso acontece n?o apenas com agregados baratos, mas tamb?m com produtos de fabricantes bem-respeitados e comprovados.Mega Filmes
  • 641 Answers
It dosen't looked like a water problem. Does the water warm-up during the washing process ? If not,it might be the reason for your problem. In this case you should check the termostat and the heater. Another direction - In regular process you place the tablet inside a cell with an automatic door that should be opened during the process, maybe that this door doesn't opened in time. A very simple test for it, is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happened to the tablet.
Posted on Apr 10, 2006
This is a problem in my dishwasher also, but not every wash, someone told me it may be because the chamber that holds the tablet inside the automatic door is wet, and the tablet is stuck there and doesnt eject into the machine at the right time.. I too would like an answer - I will try the suggestion of putting the tablet into the machine and not using the door next wash and will report back - thanks Dovi
Posted on Aug 17, 2007
Tablet not dissolving
Posted on May 17, 2009
    New Friend:
I have this problem too, the repair guy 'cleaned' the dishwasher and it worked for a few months, but now its started not working properly again! Unfortunately I was out when the repair man came and my son took care of him but doesn't know what was cleaned! I clean my machine regulary with reccomended cleaners, I've even tried lemon, white vinegar and even a spot of bleach but to no avail! I'm booking the repair guy again and this time I'll be in to watch exactly what he does!
Posted on Feb 22, 2010
We are now experiencing the same problem. At the end of a cycle the tablet is at the bottom of the dishwasher - undissolved! We have only just started having this problem and had the dishwasher for over a year.
Did everyone above solve their problems? If so, what worked?
Thanks Jo.
Posted on Jan 12, 2008
    New Friend:
I too have had this problem for past few months, and now driving me mad! Dishes still dirty at end of cycle. Don't think much of solution 7 - water alone will not clean my dishes to the standard I want. Is there a LIQUID dishwasher solution on the market that anyone knows of? (I'm in a rural area with very limited shopping.....).
Posted on Feb 08, 2010
    New Friend:
I called P&G about tablets not dissolving. They offered some general tips...make sure sprayer arms can rotate freely, perhaps run hot water from sink to draw hot water up to dishwasher BEFORE starting cycle, make sure no one else is using water for showers or clothes washing machine.
I checked all those things and ran the dishwasher again (probably the 4th time with the same load of dishes). NO LUCK! Tablet still in tact. Went out and bought a box of powder Cascade detergent. Woke up this morning to find that the powder did not dissolve either...NOW WHAT?
Posted on Jan 17, 2010
    New Friend:
We were having this problem, I noticed the drain hose inside the sink cabinet had fallen down. I secured the bend in the hose high in the cabinet, behind the sink, and have had no more problems over 3 weeks. My theory is the hose must have a bend higher than the spray arm to prevent the wash water from draining out during the wash cycle.
Posted on Jan 04, 2017
    New Friend:
My 13 month old dishwasher is also no longer dissolving the dishwasher tablet. Appliance repairman says its the circulating pump which will cost $500 to repair. The machine only cost $600. Bosch customer service wants me to jump through hoops for about a month before they may authorize a repair because I'm only a month out of the manufacturer's warranty.
Posted on Feb 28, 2015
    New Friend:
I had this problem and it only started after I bought a new cutlery holder. It's slightly bigger than the other one. I think this may have been the problem.
Posted on Jun 10, 2012
  • 1,010 Answers
Before you do anything, try regular dishwasher soap and see what is happening.
Posted on Mar 10, 2013
    New Friend:
Im having the same problem, not sure where you are all from but im in the UK and liquid isnt as popular as in the US.
Posted on Mar 14, 2010
STOP USING TABLET
Posted on Dec 06, 2007
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: my bosch dishwasher won't drain
mine is doing this too. I am trying to figure out if its the pump.
Posted on Nov 14, 2009
Anonymous
  • 25 Answers
SOURCE: Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Posted on Nov 16, 2007
Tablets not dissolving no matter what brand of tablet, and not cleaning plates and glasses. Have cleaned all filters and salt and rinse aid dispensers are filled up. What could be the problem?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 08, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch exxcell dishwasher not cleaning dishes, tablets not dissolving
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 29, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
My Bosch Exxcel dishwasher wont clean properly?
the cleaning section is mostly from the circulation pump. is the pump is not working it has to be replaced .go to sears partsdirect.com and check out part first,. this will let you know the prices to fix or replace. then call ten repair person and find the cost to change the circulation pump.
Mar 13, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
The soap tablet is no longer fully dissolving in its compartment, still does so when placed directly in d/w but finish is not as good
Have a look at the top spray arm.
Dishwashers rely on the water coming out of the end to wash the powder (tablet) out of the dispenser. Other problem could be a low water level. This would need adjusting by someone who knows how for whatever brand/model you have. Hope this helps...
Dec 12, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 24 in. SGS66E02 Exxcel Built-in Dishwasher Logo
43,187 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
